spin2gui and flexgui rev b board
pilot0315
in Propeller 2
@Publison et al.
Is there a new version of the above that will work on the Rev B board??
spin2gui is obsolete, and will not work with Rev B. Use flexgui instead.
If you expect help, you need to state more than "did no work"... What is your configuration (versions of tools, operating system, location in your file system where flexgui is located, etc...)? What was the specific problem that you saw?
Other forum posters are using flexgui on their RevB boards with success, so it's quite possible that your configuration is unique.
dgately
1). All four DIP switches are pushed towards the text side of the DIP switch (ie, toward text "BOD", "Flash", "P59", "P60")
2). Jumper "LDO VIn 5V" installed
3). Jumper "Acc Hdr 5V" removed
4). Jumper "Vdd 1V8" installed
5). MicroSD card removed
6). PC's USB cable connected to "PC USB" connnector on the board
7). Green LED near "PC USB" connector is illuminated.
Both boards operational and I can get back to my projects.
Did not know of the latest gui revisions.
