Wirelessly program P2 using FlexGUI and Raspberry Pi Zero W! — Parallax Forums
I'm not sure how practical this is, but it's wicked cool (at least to me).
Set up Raspberry Pi Zero W with VNC (you don't need VNC, but let's you see a virtual desktop instead of just a terminal window..).
Figured out how to get FlexGUI going.
Now, I can program the P2 using a wifi connection and a virtual desktop.
See setup and desktop screen below.
Had to overcome a few hurdles as I'm not so good with Linux.
See steps here: http://www.rayslogic.com/Propeller2/RaspberryPiZeroW.html
3024 x 4032 - 2M
  • Spiffy! Nice work. I am sure someone will use it.
  • jmgjmg Posts: 15,200
    Rayman wrote: »
    That's cool.
    Does that also manage DTR reset, or do you need to do that manually ?
  • RaymanRayman Posts: 16,354
    I think it has to be doing the DTR...
    I do have a problem where plugging in the P2 Eval board resets the Pi though...
    Thought was a fluke, but happened again. Maybe need to be careful about power/connection sequence..
  • wow....10 bucks.....how fast?
  • This setup would probably work pretty well with VS Code's remote workspace thingy. Probably better than VNCing into the Pi.
    Even better would be to write a script that replaces the regular loadp2 (with opening an SSH connection to the Pi, SCP-ing over the binary to a temp file and then running loadp2 on the Pi).
    mrchillin wrote: »
    The wifi seems plenty fast... The CPU itself is on the slow side for sure... But, compiling the simple examples is plenty fast enough.
    edited 2019-11-16 23:41
    I'm also using Visual Studio to remotely compile and execute c++ code on the Pi Zero.
    This seems to work fairly well for programs I want to run on the Pi.
    My next step is to connect Pi and P2 over SPI bus...
