Inexpensive Concentric Rotary Encoders
ke4pjw
I am looking into creating a prototype for a ham radio accessory that requires knobs. I would like to use concentric rotary encoders, There will need to be 6 encoders and they would be paired together. A concentric package would be nice and reduce the realestate needed. They appear to be very expensive compared to single encoders. Like a 10x price difference.
Do you guys have any suggestions?
Terry
Terry
What about adding an uC to convert the standard encoder output to concentric?
One uC could take the 6 inputs and provide 12 outputs.
https://www.amazon.com/Dual-Concentric-Encoder-Switch-Knob/dp/B079SGWVZC
Do both knobs need adjusting simultaneously ? Ie. would having a small selector button beside a single encoder allow dual functionality for reduced cost.
Probably only practical for occasional adjustments, or may rapidly become annoying!
example: ALPS EC10E1220503
Suppose you'd need to find a suitable shaft-in-shaft and matching knobs. Perhaps they exist.......
Those are always going to be costly, thanks to the
a) very low volumes and
b) complex shaft tooling needed + custom knobs
Even if you could sort the encoder sensor side, you still need the mechanics of 2 custom knobs and 1 hollow shaft.
What about a single encoder with a push-button on the shaft ? - Maybe that could emulate a concentric part, without the hollow shaft complexity ?
http://www.winzurf.co.nz/Single_Track_Grey_Code_Patent/Single_track_Grey_code_encoder_patent.pdf
OzProp put me onto this...
I like that idea! That may work. I will need to think about how I could utilize it.
The project is to add the "missing knobs" to my radio. ie. To have knobs to adjust IF width, notch filter, spectrum bandwidth, etc without having to go two and three menus deep to set the single knob that can adjust them.
https://www.mouser.com/ProductDetail/ALPS/EC11E09244AQ?qs=sGAEpiMZZMsWp46O%2Bq11WbJRzXHpSzpXwpRYQLsQ7q8=
https://www.ebay.com/itm/10-pieces-12-mm-key-switch-rotary-encoder-switch-LW/183918656522
I see Alps have other items too...
These are cute
https://www.alps.com/prod/info/E/HTML/Encoder/Ring/Ring_list1.html
the larger ring encoders can fit over a smaller one..
and these are Potentiometer based Multi Control Devices ThumbPointers
https://www.alps.com/prod/info/E/HTML/MultiControl/Potentiometer/Potentiometer_list1.html
