regarding arlo robot speed control code.
i am running the code given below using simple ide and propeller board but it is not working can you please help me?
actually at start robot is moving but after 2-3 seconds speed is increasing and then motor stops.
ModEdit: Code tags added.
while(1)
a1=current0check(); //checking current taken by motor
delay_ms(20);
a2=current1check(); //checking current taken by other motor
delay_ms(20);
a3=anglecheck(); //checking angle between two wheels
delay_ms(20);
if(t>=50) //after approx. 10sec changing speed of one wheel from n to n+1
n=n+1;
t=0;
drive_goto(-93, 93);
pause(3000);
else
moveforward(m, n); //at starting m=40, n=40
delay_ms(10);
print("n= %d",n);
t=t+1;
void moveforward(int m, int n)
drive_speed(m, n);
pause(200);
I tried the code from this link (also given by whit) - http://blockly.parallax.com/blockly/editor/blocklyc.jsp?project=15424 , and works great for me.
Code is written with Blockly but you can also get it as a "Propeller C" format.
What type of motor controller has your Arlo? The old HB-25 motor controller or the new DHB10 ?
