When was the AppMod connector and boards discontinued?
Buck Rogers
Hello!
The BOE boards and the Super Carrier boards all show that connector. And it is called in the page this: Female 10-pin dual row connector for optional AppMods .
What I'm looking for is a board who can translate the connections into ones that I can use with a minimum of efforts.
Suggestions please folks.
And this message is sponsored by the New Rebel Alliance. Please no donations at this time.
https://web.archive.org/web/20050210014204/http://www.parallax.com/html_pages/products/boards/appmods.asp
That makes sense, okay Publinson thank you for your research. But, ah, wasn't there a discussion someplace regarding making the module connector style available in roughly the same way the Prop One VHDL is now? I suspect I'm busy chasing a zebra or worse here.
https://www.jameco.com/z/PCB-463-R-Protoboard-2-7-16X4-1-8-Plated-Thru-Pad-Hole-674-Holes_263207.html
and a header to match the pinout:
https://www.jameco.com/z/7000-1X40SG-R-Connector-Unshrouded-Header-40-Position-0-100-2-54mm-Straight-Thru-Hole_160882.html
Not sure what you mean by "Prop One VHDL". VHDL is a hardware description language(program).
Ah okay. I believe I have in stock header pins who would work. Also protoboard blanks. As for the VHDL reference, I believe some time ago, and about the time the Prop 2 design stages were announced, the company also announced that the VHDL used for creating the Prop 1 were released under the same licensing that were later used for the freely available Prop 1 tools for open source work.
