Need help with 360 degree continuous rotation servo
Hello,
I'm new to the forums, so this is my first post. I recently bought a 360-degree continuous rotation servo (data sheet here, and I'm having issues getting to work correctly with an Arduino project I'm using for research. I can get the servo to go to desired angles, except when I get close to 360, or try to do more than one rotation, like requiring a position of 540 degrees. In that case, the servo starts spinning wildly out of control until I power it down, and no amount of PID tuning can correct it.
I have quite a bit of experience tuning PID settings, so I'm fairly certain the issue lies in my coding. I followed the examples on the data sheet, making only a few slight changes to make it work in Arduino. The [relevant] code is attached below. The first is the function I'm using to control the servo, which is what comes directly from the data sheet. The only change I made was to the calculation of angle, because the equation on the data sheet seemed to make the motor spin in the opposite direction required. The equation is commented so it's still there and visible, however, and the modified version is just above it.
Am I doing something obviously wrong? Admittedly, I'm not good at programming, so I feel like the error definitely lies here. I would greatly appreciate any help. Thanks in advance!
void servoAngleControl()
errorAngle = targetAngle - angle;
* From the Parallax 360 spec sheet
while(1)
tHigh = pulseIn(PIN_FEEDBACK, HIGH);
tLow = pulseIn(PIN_FEEDBACK, LOW);
tCycle = tHigh + tLow;
if ( tCycle > 1000 && tCycle < 1200)
break; //valid tCycle;
dc = (100 * tHigh) / tCycle;
angle = ((dc - dcMin) * unitsFC) / (dcMax - dcMin + 1);
//angle = (unitsFC - 1) - ((dc - dcMin) * unitsFC) / (dcMax - dcMin + 1);
if(angle < 0) angle = 0;
else if(angle > (unitsFC - 1)) angle = unitsFC - 1;
// Since we might be looking at positive or negative measurements above +/- 360 degrees, this keeps track
// of the number of full turns. q2Min is an abbreviation for quadrant 2 minimum, which is 90 degrees, and
// q3Max (quadrant 3 maximum) is 270 degrees. So, if the previous theta measurement was in the 1st
// quadrant, and the current theta measurement is in the 4th quadrant, we know we the angle
// transitioned from a high value to a low value, so increase the turns count. Conversely, if the previous
// theta was in the first quadrant, and the new theta is in the fourth quadrant, we know that the angle
// transitioned from a low to high value, so decrease the turns count.
if((angle < q2min) && (pAngle > q3max)) // If 4th to 1st quadrant
turns++; // Increment turns count
else if((pAngle < q2min) && (angle > q3max)) // If in 1st to 4th quadrant
turns --; // Decrement turns count
// This takes the number of turns and the theta angle measurement, and constructs the total angle
// measurement from zero, allowing for large angle values in the +/- 2,147,483,647 degree range.
if(turns >= 0)
tAngle = (turns * unitsFC) + angle;
else if(turns < 0)
tAngle = ((turns + 1) * unitsFC) - (unitsFC - angle);
// Since the 0 to 359 and 359 to 0 degree crossings rely on the angle from the previous time through the
// loop, the value of thetaP (theta previous) is copied from the current theta angle before the next loop
// repetition.
pAngle = angle;
result = pidLoop.Compute();
if (result == 1)
if (errorAngle > 0) errorOffset = 30;
else if (errorAngle < 0) errorOffset = -30;
else errorOffset = 0;
servoVal = 1480 - (outputVal + errorOffset);
camControl.writeMicroseconds(servoVal); //Move the servo
The updated code is pasted below. I made a change to the angle calculation, where I made a typo and had not previously recognized it.
void servoAngleControl() { errorAngle = targetAngle - angle; /********************************************************************************* * From the Parallax 360 spec sheet *********************************************************************************/ while(1) { tHigh = pulseIn(PIN_FEEDBACK, HIGH); tLow = pulseIn(PIN_FEEDBACK, LOW); tCycle = tHigh + tLow; if ( tCycle > 1000 && tCycle < 1200) { break; //valid tCycle; } } dc = (100 * tHigh) / tCycle; angle = ((dc - dcMin) * unitsFC) / (dcMax - dcMin); //angle = (unitsFC - 1) - ((dc - dcMin) * unitsFC) / (dcMax - dcMin + 1); Serial.print("compAngle: "); Serial.println(angle); if(angle < 0) angle = 0; else if(angle > (unitsFC - 1)) angle = unitsFC - 1; // Since we might be looking at positive or negative measurements above +/- 360 degrees, this keeps track // of the number of full turns. q2Min is an abbreviation for quadrant 2 minimum, which is 90 degrees, and // q3Max (quadrant 3 maximum) is 270 degrees. So, if the previous theta measurement was in the 1st // quadrant, and the current theta measurement is in the 4th quadrant, we know we the angle // transitioned from a high value to a low value, so increase the turns count. Conversely, if the previous // theta was in the first quadrant, and the new theta is in the fourth quadrant, we know that the angle // transitioned from a low to high value, so decrease the turns count. if((angle < q2min) && (pAngle > q3max)) // If 4th to 1st quadrant turns++; // Increment turns count else if((pAngle < q2min) && (angle > q3max)) // If in 1st to 4th quadrant turns --; // Decrement turns count // This takes the number of turns and the theta angle measurement, and constructs the total angle // measurement from zero, allowing for large angle values in the +/- 2,147,483,647 degree range. if(turns >= 0) tAngle = (turns * unitsFC) + angle; else if(turns < 0) tAngle = ((turns + 1) * unitsFC) - (unitsFC - angle); angle = tAngle; // Since the 0 to 359 and 359 to 0 degree crossings rely on the angle from the previous time through the // loop, the value of thetaP (theta previous) is copied from the current theta angle before the next loop // repetition. pAngle = angle; /********************************************************************************/ /********************************************************************************/ result = pidLoop.Compute(); if (result == 1) { if (errorAngle > 0) errorOffset = 30; else if (errorAngle < 0) errorOffset = -30; else errorOffset = 0; servoVal = 1480 - (outputVal + errorOffset); camControl.writeMicroseconds(servoVal); //Move the servo } delay(20); }
