Programming the Prop Mini
denno
in Propeller 1
Question...can I use the USB to serial adaptor that is used to program the Basic Stamps, to program the Prop Mini, if I reconfigure the Rx,Tx,Vcc and ground to match the pins on the Prop Mini, instead of having to buy the "Prop plug" for $16..??
Thank you...denno
Thank you...denno
I use the CP2102 USB 6pin version (~$1.50) There is a link in my P8XBlade thread, which also powers my board (5V). Do NOT use the 3V3.
So, you will require the DTR transistor reset circuit - some manage to get away with using just a capacitor instead but it’s a case of try and see as it may not always work reliably. You will also need to regulate the 5V to 3V3.
I have both the transistor reset circuit and 3V3 regulator on my boards.
Thanks...denO
When feasible, I keep these assigned serial devices (i.e. Parallax Serial LCD #27979). During programming, the LCD displays garbage characters, which is easily remedied. Make sure that your arrangement similarly causes no harm.
Thanks..dennO
At power up the P1 loads the program from EEPROM faster as you can hit the program button so before you are able to reprogram your old program is already running.
so like @hatallica said, be careful of what you are using the pins for.
Well I have already been working with the FLIP and Propbasic on/with several programs using this computer. If I am already downloading programs into the FLIP, do I have to download more drivers to program the Prop Mini?
Thanks..DennO
I think that comment was more applicable to older operating systems
