Sanity Check, Please...
JonnyMac
in Propeller 1
I picked up a couple LewanSoul LX-16A actuators a few months ago, probably inspired by a forums post. Today I actually started writing a driver for it (Spin sitting on top of FDS). On connecting a 'scope to measure the message turn-around time I saw something I didn't expect. It looks -- to me, anyway -- that the LX-16A is driving the line to 3.3v for a "1" instead of allowing the line to be affected by the pull-up.
Am I mistaken?
I'm almost done with the driver so I'll post it later. The LX-16A doesn't match the Dynamixel, but it is pretty good and quite a lot cheaper.
Am I mistaken?
ie They can float to 5V, if disabled/open drain but if you enable the CMOS drive, they have P-FETS to 3v3, for faster pullups.
Their SCH shows a light 10k pullup, to 5V, and active 74HC126 tristate buffers.
Should be fine in a P1 system, and probably Ok with any 5V MCU too.
Digging for a 5V tolerant CMOS part, finds this Nexperia data
'74LVC126A Quad buffer/line driver with 5 V tolerant input/outputs; 3-state
The 74LVC126A consists of four non-inverting buffers/line drivers with 3-state outputs, which are controlled by the output enable input (nOE). A LOW at nOE causes the outputs to assume a
high-impedance OFF-state.
Inputs can be driven from either 3.3 V or 5 V devices. When disabled, up to 5.5 V can be applied to the outputs."
I think it may be safe to connect to an unbuffered Propeller pin using a stiff pull-up. Do you agree?
BTW - no need for a sanity check, since you a forumista you are insane to some extent
I didn't then, but I have done that recently. I was struggling over the weekend and found a box of LX-16A near my desk, so I decided to start on a P2 driver. I put a 10K pull-up to 3.3V to keep the line at idle state when the P2 is booting up or the LX-16A is not transmitting. So far, so good.
