Here's some code snippets for 3 of the boards (AV, Control and LED Matix), and a modified pins object.
I figure they might be a handy baseline to get started with your boards. I used the spin2gui compiler.
About the audio amp - a friendly warning- it's super loud!
Be cautious when using headphones, until you figure out your volume levels
The attached AV demo puts out a really calming sound through the audio-out jack (probably good for yoga). Recommend a listen !
It's a good example of how clean and clear the P2 reproduces sound.
The boards are going through test right now. Apparently there's a huge amount of labor to go through each add-on (rinse, repeat, rinse, repeat).
And the web editor confirmed these will be live on the webshop today or tomorrow, on part numbers 64005 and 64006.
Kind regards, Samuel Lourenço
The chip is just a headphone amplifier.
https://docs.google.com/document/d/1FTGV1Mn1hwayEaKut5Ej6vmWdjirVlP9TQqyA0wRs34/edit
There's some basic documentation here:
The part is: Maxim : MAX4411ETP+
You probably want to see the schematics - Will go see where they are and post them soon.
Thanks Publison. I'd forgotten they'd already been printed!
Had the folder opened when I found my boards were shipping today.
Looking forward to playing with them!
Cool, thanks - I found the part from the markings in the photo, and heeded the 3.3V only
warning...
https://propeller.parallax.com/
https://github.com/parallaxinc/propeller/tree/master/examples
If anyone has content they'd like to share to the Propeller 2 Github, there's some instructions here: https://github.com/parallaxinc/propeller/wiki/Contributing
