HyperRAM breakout for P2-EVAL-ES — Parallax Forums
Here’s a small HyperRAM breakout board I’ve developed for the P2-EVAL-ES. I just plugged my earlier OSHPark HR carrier (the purple board) into a new PCB that provides access to P11…0 on the P2-EVAL. There’s also a WS2812B on there to serve as a cool status indicator.
I’m using LabVIEW to communicate with my EVAL at 3Mbaud. Presently the P2 is running @ 240 MHz (no thermal issues at all). The code accesses the 8 megabyte HR chip as 65536 x 128 byte blocks. The HR read and write routines that transfer these 128 byte blocks between HUB RAM and HR each execute in ~1500 nsec, equating to a transfer rate of 85MB/sec. I’ve not tried to push my setup beyond 240 MHz as I don’t currently have any cooling - but so far everything is looking good.
Its summer down here in Oz so progress now takes a back seat to some holiday time - but I do plan to post code and design files in case others wish to populate their own boards. I think this will likely be some time after our next Melbourne P2 catch-up – Jan 10th ??
1512 x 2016 - 672K
  • roglohrogloh Posts: 6,363
    edited 2019-01-04 01:20
    Nice work RJSM. 85MB/s would in theory be able to support a 800x600 frame buffer with 50% time sliced access for writers and 50% for reading in the pixels to be displayed. Trick would be in designing the arbiter to fit in with the transferred video blocks for getting some reasonable write efficiency.
  • jmgjmg Posts: 15,200
    Wow, so it all works well ?
    RJSM wrote: »
    .. The code accesses the 8 megabyte HR chip as 65536 x 128 byte blocks. The HR read and write routines that transfer these 128 byte blocks between HUB RAM and HR each execute in ~1500 nsec, equating to a transfer rate of 85MB/sec...
    That comes to appx 98ms repeat rate ? Did you try slowing that down, to see when/if refresh issues ever bite ?
    The data specs a tight 4us for tcms, and is vague on if refresh is one-click-per-cms, or if refresh runs all the time when deselected.
    The latter would mean more choice in when to pause for refresh.
  • That repeat rate of 98ms is not counting the time taken to move data into and out of the fixed RD/WR buffer spaces I am using, nor the generation of 65536x128 bytes of random #'s, nor the checking of the data integrity each WR/RD. I just timed 100 accesses to the entire HR data space and each full access is taking 1.4s - that's writing 8MB and reading 8MB reads plus doing all the other stuff. As rogloh pointed out it's going to take some work to usefully harness HR in a real video application...
    Re the refresh question I did investigate that back in FPGA emulation days and my recollection is that it appears refresh runs all the time.
  • Really looking forward to seeing this, RJSM, and labview too.
    Yes, 10th Jan is the day... looking forward to it.
  • By the way, is the Hyperram running from 3v3 or 1v8?
    Tubular wrote: »
    3v3 (BLL suffix) P2 ports cannot manage 1v8.
  • As far as I know, P2 ports can do digital 1v8, its just the analog (sigma delta) etc that suffers
    Impedance drive and speed may also be affected
  • Running it from 3v3 VIO
    Tubular wrote: »
    I thought Chip ran some tests, and the level shifters could not manage 1v8 VIO ?
    As you say, even if they could reach 1v8, the speed would be very poor.
  • Ok, I guess we need Chip to chime in here and confirm the latest
    Separate to VIO, there's still a way to use the DACs to drive 1v8 output at full speed (2ns settling dacs), and a corresponding 'threshold input' (using slow dac feeding into input comparator) to achieve 1v8 inputs.
    Testing this with Hyperram would really validate this 'soft-vio' aspect of P2, since it would simultaneously push the clock, verify read write data integrity etc
  • Hi @RJSM
    You did an awesome work with those Hyper things!
    Apart from the sufix of the chips (BLL or ALL) one chooses to mount on them, the simple existence of the breakouts will enable the validation of a lot of concepts and many kinds of tests.
    These will include the Hyperflash and the duals too (Hyperflash + Hyperram).
    Eager to take a look at the software you did.
    Henrique
  • How can we get a pcb? Did you assemble this one yourself? How did you go with the BGA?
    I'd love to try this out beforehand since I have designed a one onto my new P2D2.
  • Peter
    Yes I did the PCB's and assembly myself. I have a Beta Layout reflow controller and an el-cheapo Kmart toaster oven. The former was pretty pricey but its been great for doing numerous SMT projects; many of the most recent have been instruments built with the ESP32 while eagerly awaiting arrival of the P2. I've got some plans to team the ESP32 up with the P2 down the track - but that's another story.
    Here's the link to the controller : https://uk.beta-layout.com/estore/order_product_details.html?wg=1&p=613 - but from what you've posted I reckon you've got a very good smt setup already.
    Soldering the BGA was just a matter of very carefully placing the package onto the PCB using the silkscreen outline for placement. I did some reading about appropriate pad sizes to properly accommodate the balls and had a few initial failed attempts - but it doesn't appear to be too problematic. The chip seemed to go down onto those OSHPark gold plated pads quite nicely. Obviously a next version PCB would be a single board design - really not much work at all - but I'm hoping Parallax will do one first ! Would be great to see HR accessible from TAQOZ too.
    I am out of town now (we have escaped the Melbourne 42C heat today to head down the coast till mid next-week) but when I get back i'll check my PCB stocks. The green board was a JLCPCB job ($2 for 10 boards) and I should still have 9 of these left over - could send one up to you in Brisbane. The OSHPark one I'm not sure - I might have 1 left - but i'll check that too. I have a couple of dozen HR chips as well. There's a 16MB version that I bought a while back too but have not tried that out. More than happy to help in any way I can once back in town.
  • Hi @RJSM, I may be interested in a board at some point if you choose to make any more and they are already on a 0.1 inch grid. Can chat about it next week during our next Prop meet in MEL. My own board already has some footprint provided for a PSRAM memory device using QSPI (which is not quite as fast though perhaps slightly simpler to use), however it could also be interesting to muck about with HR as well at some point down the track.
