Looking for adhesive suggestions
I have a plastic part that is broken and I'd like to glue it back together. It's the swivel mount for the AM ferrite rod antenna on the back of a 70's Pioneer stereo receiver. I'm not sure what type of plastic it is. Seems slippery, shiney and maybe a little waxy. Possibly nylon?
Anyway I first tried super glue. Didn't hold. Then super glue for plastics. That held for a short minute then came apart. Next I tried 2 part epoxy made for plastics. Held a little longer but then broke. I should mention that the parts fit snug together and that I let each one cure for 24 hours plus before applying any pressure. The adhesives I used were all Loctite brand products.
Anyone have any suggestions? Someone told me to try the adhesive you see advertised on TV that you cure with a UV light. I always felt that was a gimmick but have not heard any actual experience with it.
A picture of the broken part would be helpful.
Repeat and put fibers in the other direction.
Repeat that for a few layers. Sewing thread can work great. Use a lot of them, like every half mm or so.
If you wrap those around the part in the direction where that is possible, and make sure the fibers cross the break and engage both parts in the other direction, you will end up with a very strong composite.
You do not need to let it dry completely, but you do want a firm set.
Also important to avoid stress during the process.
Takes a bit to do, but I have been surprised more than once at the outcome.
https://epoxyworks.com/index.php/gluing-plastic-with-gflex-epoxy/
By using the recommended G/flex epoxy and following its instructions to the letter, I was able to repair the crack, and it's as strong as the original poly ever was.
If that turns out to be feasible, and if any surrounding structure allows it, you might consider modifying the model. It looks like there might be enough room between the mounting holes for some fairly thick gussets extending from the sides of the ball cup down to the flange, which should add some strength.
https://ebay.com/itm/Pioneer-SX-1250-SX-1050-SX-950-SX-1010-Base-Mount-Holder-for-Antenna-W72-092/142935922017?hash=item2147a51561:g:IHwAAOSwEzxYZtbk
Not very nice looking and in fact is not at all like the original.
https://ebay.com/itm/Pioneer-NEW-AM-Antenna-Mount-Base-SX-950-1050-1250-1010/271677290831?_trkparms=aid%3D333200%26algo%3DCOMP.MBE%26ao%3D1%26asc%3D20170829074220%26meid%3D0b7f6b456f4d4835993a0e358656dc6d%26pid%3D100817%26rk%3D1%26rkt%3D12%26sd%3D142935922017%26itm%3D271677290831&_trksid=p5713.c100817.m4967
I could have sold you an original I have. I would have cost you $1,200 as it's attached to my SX-1250.
Also rebuilding a pair of these...
I also own a pair of HPM-100's. They don't build them like the HPM-100's anymore: Tweeter, Super Tweeter, Mid-Range and a real Woofer.
Don't even bother with cheap superglues. Use Loctite or other proven brands. Clean off any other glues you have tried prior. I like thick CA glue (Great Planes) and accelerator (zip kicker or equivalent).
Finally, per jones' comment, you want to build up MASSIVE material gussets outside. MASSIVE. Rough up the entire outside area for best adhesion with a rough file and/or rotary tool, and build several layers of coating, alternating glue/kicker etc.
MASSIVE. Did I say massive? Assume that the fracture area provides no strength and that 100% of the repair is external.
MASSIVE. Ugly but functional.
as a splint that slightly melted into the part, and that wasn't easy to get right. Here there is significant
mechanical load, the repair needs to be stronger than the original really, since it failed.
Dremel/machine out a new part from a block of delrin?
Ditto for aluminium, and add an insulating gasket/bushings to maintain electrical isolation?
