Outputting PUB items as text to composite out for debugging hydra
in Propeller 1
Hi Smart People,
I am comfortable with the Arduino IDE, where I can use the serial monitor to output variables for learning/debugging.
I am doing the same with the hydra composite out using itoa(foo,@sbuffer) then gr.text(x,y,@sbuffer) to output some VAR variables from the "VAR" code blocks, but what I really need is to output an x,y from PUB start | i, x,y
There is no doubt something I am missing. Do you have any advice or recommendations in how I can better word the question? I'm stuck.
Thank you for your time.
KB
KB
VAR long x,y
PUB start | i {, x,y}
Notice that I've commented out the local variable definitions, but they're in the comment as a reminder. This may not work if there are other uses of x or y in the program.
With this change, you can display x and y elsewhere in your program.
Interesting, so essentially remove x,y from the PUB block and add them to the VAR block if I understand you correctly. I'll give that a go.
Cheers,
KB
