Connecting 5V signals to P2? — Parallax Forums
marsman2020marsman2020 Posts: 71
edited 2018-11-21 05:24 in Propeller 2
What would be the simplest way to connect a 5V signal to the P2? Are there diodes in the pin circuit such that a simple series resistor to limit current in the diode would work? Or is a resistor divider or active level shifter required?
I have an existing P1 board with 74LS series logic running through series resistors to the P1. Looking to build a modified version with a ribbon cable connection for the Eval board.
    edited 2018-11-21 05:38
    Voh of any ttl is typically around 3.5V anyway unlike 5V CMOS which does output 5V. I would use a resistor but Chip reckons 5V is unlikely to be a problem. If speed is not a problem you can even use 100k which is what i do for 24V PLC type inputs.
    If it worked for the P1 it will work for the P2
  • cgraceycgracey Posts: 14,320
    edited 2018-11-21 05:54
    5V pull-up through a weak resistor is not a problem. Don't drive the Vxxxx pin at 5V, though. I think you would shorten the life of the chip.
  • jmgjmg Posts: 15,200
    Can you still buy 74LS ?
    What speed, and how many channels ?
    There are diodes there, so a series R can be used, but you need to watch the total pullup current does not exceed the minimum P2 drain, otherwise the 3.3V can start to lift.
    For fastest and lowest power, the dual-supply levels shifters work very well.
  • https://www.futurlec.com/IC74LS00Series.shtml
    Besides, whether one can buy them doesn't actually get at the problem, given they are right there on the board :D
  • jmg wrote: »
    Yup, all day long from Digi-key brand new.
    14 pins, max speed is 10 MHz (limited by S-100 bus clock)
