LMM code in PROPBASIC
denno
in Propeller 1
Bean....I have an experiment going on using the FLIP, and PROPBASIC. I have written code to all 8 cogs, using the command TASK. Now, if I put LMM after the TASK name, on all 7 COGs after the PROGRAM start, the first COG (0) will start, but the rest of the COGs do not run. I still get a successful download to the FLIP. Now, if I remove the "LMM" from the last COG(7), but leave the rest of the COGs with the LMM in place, the download works and all COGs are running.
If I remove all "LMM"s the program still loads, and runs correctly... so, what does the "LMM" do?
DennO
DennO
Usually the main program is LMM and all of the tasks are native (not LMM).
Not sure why you wouldn't be able to run 7 task that use LMM (that is not the norm, but should work).
Bean
https://forums.parallax.com/discussion/89640/announcing-large-memory-model-for-propeller-assembly-language-programs
