P2 Boot Options / Sequence/ Pull-ups / Pull-downs
ke4pjw
Is this documentation for booting the P2 correct?
Looks like there were some very last minute changes to the boot options just before the ROM was shipped to On-Semi in May.
Discussion found here: http://forums.parallax.com/discussion/162298/prop2-fpga-files-updated-2-june-2018-final-version-32i/p139
Do we know if P59 was floating when chip was attempting to program the P2 last night? Might that have been detected as a pd and forced serial to not work?
Chip, Ken, et al, thank you so much for sharing the live stream yesterday. You guys were up on the 62" TV most of the evening, much to the chagrin of my wife and kids. They didn't understand my excitement
P61 spi-CS sd-CK pu = spi flash
P60 spi-CK sd-CS pu = SD card (pullup is internal on the card)
P59 spi-DI sd-DI pu = Serial pd = Stop
P58 spi-DO sd-DO
P59 pullup = goto Serial
P60 pullup = goto SD card
P61 pullup = goto SPI Flash
P59 pulldn = Stop
else = goto Serial
Definitely need a pullup on P59...
I used the Propeller Serial Terminal for most of my testing.
A reset can be issued by toggling DTR.
Then the sequence to identify the prop is preferred (cannot recall exact char sequence) to be sent. This sets the autobaud in P2. Then IIRC an <esc> will pass control to TAQOZ, or Ctl-D will pass control to my debug/monitor. Both TAQOZ and MONITOR identify themselves so you know you're there. You can go between TAQOZ and MONITOR by the same keys (Monitor requires <esc> followed by <cr>).
Chip, I hope this refreshes your memory.
IIRC a memory dump is
100 L<cr>
100 . 180 L<cr>
00100 . 00180 L<cr>
spaces shown are not required
Postedit: fixed syntax
But it should not have been necessary to have a pull-up on P59 IIRC. Perhaps the ROM code is waiting too long after returning P59 direction to input before sampling the pin, or the analog is providing a higher pulldown resistance than anticipated.
Anyway, we can certainly test the times and values required for the various boot options.
Was there a late change to the monitor syntax?
I'm not seeing any response here. (Nano with latest FPGA image)
00100-00180m for a byte listing
