pBasic Displays
in Propeller 1
Guys,
Now that I can program my Propeller Controllers in pBasic, I would like to send system data to a flat screen display. What, in your opinion, would be the most compatible display for the Propeller and the pBasic micro controller?
I would like to display alphanumeric characters...about sixty, at any location on the display. Color would be nice but not required. A sample data set would be
MAIN Pump Output Tank A Level: 0 to 100%
Pressure: 0 to 4,000 psig Tank B Level: 0 to 100%
Temperature: -20 to 200 Degrees F Mixing Tank Level: 0 to 100%
Flow Rate: 0 to 2 Gallons per Minute
Reactor Humidity: 0 to 100% CO2: 0 to 500 ppm
One-wire data will be gathered by the Propeller and displayed. Calculations will be performed by the Propeller and displayed.
All micro controller code will be developed on a computer, downloaded to the micro controller then the USB cable disconnected.
Your assistance will be helpful.
Discovery
Discovery
But, after it is all said and done, the display from Seetron is very easy to use, and I should add that the 3.3 volt out from the propeller is enough to run the display, as the input to the display, requires 5 volts.
THe following is a code snippit that I use to send data to the propeller....to give you an example...notice the CONSTANTS list, as I like to set alot of them, to make the code easier to read..hope this helps...
DEVICE P8X32A, XTAL1, PLL16X XIN 5_000_000 '========CONSTANTS============ baud CON "N9600" carr_return CON 13 clrLCD CON 12 'clear the screen on the lcd posCMD CON 16 'position the curser command hideCUR CON 4 'hide the curser command blinkCUR CON 6 'blink the curser command degreeSYM CON 223 'the "degree" symbol receive_data CON 255 backLTon CON 14 'turn the back light on backLToff CON 15 'turn the back light off brightness_ctl CON 27 quarter_bright CON 48 half_bright CON 49 three_quarter_bright CON 50 full_bright CON 51 beep CON 7 'beep command right_align CON 18 'RIGHT ALIGN COMMAND start_big_char CON 2 end_big_char CON 3 astrike CON 42 block_char CON 134 carReturn CON 13 'carriage return command blank_char CON 32 left_arrow CON 127 right_arrow CON 126 LR_arrow CON 131 LL_arrow CON 128 UR_arrow CON 129 UL_arrow CON 130 down_arrow CON 132 up_arrow CON 133 equal_sign CON 61 first_line CON 64 second_line CON 104 no_char CON 0 TASK LCD_1 'this TASK is running in COG 7 temp_1 VAR LONG 'the temp_1erature data, itself.. temp_2 VAR LONG stringVOLT VAR LONG integerVOLT VAR LONG stringVOLTtenth VAR LONG stringVOLThundreds VAR LONG LCD_data_out PIN 2 'Define a string variable: ' string1 HUB STRING(3) 'Use STR to place the ASCII' representation of temp_1's value into a string ' string1 = STR temp_1,3 'THEN display it. ' SEROUT LCD_data_out, baud, string1 SEROUT LCD_data_out, baud, clrLCD SEROUT LCD_data_out, baud, beep SEROUT LCD_data_out, baud, backLTon SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 64 SEROUT LCD_data_out, baud, "TEMPERATURE IS" SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 84 SEROUT LCD_data_out, baud, "TEMPERATURE IS" SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 104 SEROUT LCD_data_out, baud, "VOLTAGE IS" DO RDLONG degrees_1, temp_1 'reading the temperature data that is in the HUB PAUSE 200 temp_1DEC = STR temp_1,3 RDLONG degrees_2, temp_2 'reading the temperature data that is in the HUB PAUSE 200 temp_2DEC = STR temp_2,3 RDLONG volt_location, stringVOLT RDLONG tenth_location, stringVOLTtenth RDLONG hundreds_location, stringVOLThundreds PAUSE 200 actualVOLT = STR stringVOLT, 1''2''3''4 actualVOLTtenth = STR stringVOLTtenth,1 actualVOLThundreds = STR stringVOLThundreds,1 SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 79 SEROUT LCD_data_out, baud, temp_1DEC SEROUT LCD_data_out, baud, degreeSYM SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 99 SEROUT LCD_data_out, baud, temp_2DEC SEROUT LCD_data_out, baud, degreeSYM SEROUT LCD_data_out, baud, posCMD SEROUT LCD_data_out, baud, 115 SEROUT LCD_data_out, baud, actualVOLT SEROUT LCD_data_out, baud, "." SEROUT LCD_data_out, baud, actualVOLTtenth SEROUT LCD_data_out, baud, actualVOLThundreds LOOP ENDTASK LCD_1Thank you.
Discovery
