Is anyone aware of any sample SPIN programs for the above wi-fi modules?
I have done a search of obex and the web I cannot find any.
Many thanks . .
I think the op wants examples of spin that shows using the CMD structure provided by the firmware included with it.
I use the wx device's serial port with fullduplexserialplus on the prop to send ANSI ESCAPE control codes using the telnet port 23 with putty.
Its a nice way to format the debug output.
Example code is just dumping ansi codes to the serial input on the wx device.. Its pretty simple.
Connect to port 23 of the ip for your wx device using putty.
''* Telnet Wireless WX Ansi Command Demo *
''* Author: Clock Loop @ parallax forums *
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
CON
Tx = 30 'serial out to wx device
Rx = 31 'serial in from wx device
OBJ
Term : "FullDuplexSerialPlus"
Pub Port23Display | Years, Dayz, Hour, Mnit
Years := 13
Dayz := 6
Hour := 3
Mnit := 45
term.start(Rx, Tx, %0000, 115_200) '1cog start telnet terminal
waitcnt(80_000_000 + cnt)
term.str(string(27)) 'Set command mode
term.str(string("[2J")) 'Clear telnet screen
term.str(string("[1;1f")) 'Set Position
term.str(string("[0m")) 'Turn off character attributes
'--------------SOME ANSI COMMAND CODE INFO---------
'term.str(string(27)) 'Set command mode
'term.str(string("[2J")) 'clear screen
'term.str(string("[0m")) 'Turn off character attributes
'term.str(string("[1m")) 'Turn bold mode on
'term.str(string("[2m")) 'Turn low intensity mode on
'term.str(string("[4m")) 'Turn underline mode on
'term.str(string("[5m")) 'Turn blinking mode on
'term.str(string("[7m")) 'Turn reverse video on
'term.str(string("[8m")) 'Turn invisible text mode on
'term.str(string("#3")) 'Double-height letters, top half
Esc#3 Double-height letters, top half DECDHL
Esc#4 Double-height letters, bottom half DECDHL
Esc#5 Single width, single height letters DECSWL
Esc#6 Double width, single height letters DECDWL
Repeat
term.str(string("[5;5f")) 'Set Position
term.str(string("[31m")) 'Red color text
term.str(string("UpTime : "))
term.dec(Years)
term.str(string(":Years "))
term.dec(Dayz)
term.str(string(":Days "))
term.dec(Hour)
term.str(string(":Hours "))
term.dec(Mnit)
term.str(string(":Min "))
Dat
Terms of Use: MIT License
Permission is hereby granted, free of charge, to any person obtaining a copy of this
software and associated documentation files (the "Software"), to deal in the Software
without restriction, including without limitation the rights to use, copy, modify,
merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to the following
conditions:
The above copyright notice and this permission notice shall be included in all copies
or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
The propeller RES pin goes to the WX RES pin. (gpio12, DTR)
The propeller TX pin goes to the WX DI pin.
The propeller RX pin goes to the WX DO pin.
Connect the wx device to your network and open its ip address.
The propeller wx page should show.
From there you can upload a new copy of the latest firmware if there are any (https://github.com/parallaxinc/Parallax-ESP/releases)
Then run this by pressing the start button, search for program, type in cmd.exe
press enter and open the program when it finds it
that opens a command prompt, then paste this command.
Excellent catch, no idea how it slipped in. Original fixed.
I suppose i could have made the timer code actually work by including the proper code..
But, this was just a demo on how to format ansi command codes to a ansi compatible terminal program over telnet.... didn't want to add more complications that might confuse.. thanks again!!
Esc[Line;ColumnH
Esc[Line;Columnf Cursor Position:
Moves the cursor to the specified position (coordinates).
If you do not specify a position, the cursor moves to the home position at the upper-left corner of the screen (line 0, column 0). This escape sequence works the same way as the following Cursor Position escape sequence.
Esc[ValueA Cursor Up:
Moves the cursor up by the specified number of lines without changing columns. If the cursor is already on the top line, ANSI.SYS ignores this sequence.
Esc[ValueB Cursor Down:
Moves the cursor down by the specified number of lines without changing columns. If the cursor is already on the bottom line, ANSI.SYS ignores this sequence.
Esc[ValueC Cursor Forward:
Moves the cursor forward by the specified number of columns without changing lines. If the cursor is already in the rightmost column, ANSI.SYS ignores this sequence.
Esc[ValueD Cursor Backward:
Moves the cursor back by the specified number of columns without changing lines. If the cursor is already in the leftmost column, ANSI.SYS ignores this sequence.
Esc[s Save Cursor Position:
Saves the current cursor position. You can move the cursor to the saved cursor position by using the Restore Cursor Position sequence.
Esc[u Restore Cursor Position:
Returns the cursor to the position stored by the Save Cursor Position sequence.
Esc[2J Erase Display:
Clears the screen and moves the cursor to the home position (line 0, column 0).
Esc[K Erase Line:
Clears all characters from the cursor position to the end of the line (including the character at the cursor position).
Esc[Value;...;Valuem Set Graphics Mode:
Calls the graphics functions specified by the following values. These specified functions remain active until the next occurrence of this escape sequence. Graphics mode changes the colors and attributes of text (such as bold and underline) displayed on the screen.
Text attributes
0 All attributes off
1 Bold on
4 Underscore (on monochrome display adapter only)
5 Blink on
7 Reverse video on
8 Concealed on
Foreground colors
30 Black
31 Red
32 Green
33 Yellow
34 Blue
35 Magenta
36 Cyan
37 White
Background colors
40 Black
41 Red
42 Green
43 Yellow
44 Blue
45 Magenta
46 Cyan
47 White
Parameters 30 through 47 meet the ISO 6429 standard.
Esc[=Valueh Set Mode:
Changes the screen width or type to the mode specified by one of the following values:
Screen resolution
0 40 x 25 monochrome (text)
1 40 x 25 color (text)
2 80 x 25 monochrome (text)
3 80 x 25 color (text)
4 320 x 200 4-color (graphics)
5 320 x 200 monochrome (graphics)
6 640 x 200 monochrome (graphics)
7 Enables line wrapping
13 320 x 200 color (graphics)
14 640 x 200 color (16-color graphics)
15 640 x 350 monochrome (2-color graphics)
16 640 x 350 color (16-color graphics)
17 640 x 480 monochrome (2-color graphics)
18 640 x 480 color (16-color graphics)
19 320 x 200 color (256-color graphics)
I have not tested all these sequences with putty, use at your own risk. (of confusion)
And we can even generate graphics with putty and these sequences,... ANSI art.
You can also, using putty, and either the WX device or a simple serial port, view ANS files directly with the propeller, and putty.
Like this:
''* Telnet Wireless WX Ansi Art Demo *
CON
'_xinfreq = 6_250_000 ' I do my code testing on a propscope.
CON
OBJ
Pub Port23AnsiArt
Repeat
Repeat 5
term.str(@ansidata)
DAT
ansidata File "join.ans"
Dat
conditions:
I generated an ANSI image of the parallax logo using it.
But it doesn't work, so if anyone wants to figure out why the ansi files made by playscii will not work..
Was it Rayman?
Prop OS (also see Sphinx, PropDos, PropCmd, Spinix)
Website: www.clusos.com
Prop Tools (Index) , Emulators (Index) , ZiCog (Z80)
https://forums.parallax.com/discussion/160533/serial-communication-with-the-esp8266-using-the-nodemcu-firmware-script-languagelua
of course it depends what you want to do
I used ESP8266 loaded with NodeMCU running the Lua interpreter interactively.
So you just send Lua commands via serial.
You don't need any special object for this except SERIAL
Get one of these:
https://www.parallax.com/product/32420s
If you compile the above prop code i attached, using the PropellerTool software https://www.parallax.com/sites/default/files/downloads/P8X32A-Setup-Propeller-Tool-v1.3.2.zip
Generate a binary by pressing F8, and save the binary to c:\temp\propcode.binary
You can download and extract the proploader to c:\temp\proploader.exe https://github.com/parallaxinc/PropLoader/releases/download/v1.0-37/proploader-win.zip
you WILL need to change yourwxnameoripaddresshere to your actual wx ip address or name.
It will upload the code to your prop connected to the wx device on wifi.
Then you need putty https://www.chiark.greenend.org.uk/~sgtatham/putty/latest.html
And open a connection in putty, telnet port 23 on address: yourwxnameoripaddresshere
So now you can wirelessly program, and view the debug output of any propeller based project with the parallax wx device, and these instructions.
"I'll buy that for a dollar"
Optic communication between homogenous and commensurable, 8-core, 635nm emitting, phase locked loop, bit salad tossing units? http://forums.parallax.com/discussion/comment/1248240/#Comment_1248240
TheBlackBox: Release v2.0 - Propeller HSS FX/Sequencer with Digital Audio SPDIF output. http://forums.parallax.com/discussion/115258/theblackbox-release-v2-0-propeller-hss-fx-sequencer-with-digital-audio-spdif
E-Tools - Mono555 calculator, resistor calculator, voltage divider calculator, RCtime calculator, LM317 calculator, Binary-Hex-Decimal calculator, Resistor color matrix, Series LED resistance calculator, OHMS LAW calculator.
http://forums.parallax.com/discussion/81449/e-tools-html-java-script-electronic-design-tools-free-for-you
Simple fix:
dgately
(ANSI Escape codes)
http://ascii-table.com/ansi-escape-sequences.php
Like this:
You can find all kinds of .ANS files here
http://artscene.textfiles.com/
http://pc.textmod.es
The full code is attached which contains the join.ans file.
Playscii
http://vectorpoem.com/playscii/
The ANSI for the storm trooper was found here:
http://blocktronics.org/artpacks/
The Blocktronics Detention Block AA-23
You can see rendering of the pack here
http://pc.textmod.es/pack/blocktronics_detention_block_aa-23/
I didn't mean to make this about ANSI stuff.
Just showing that ANSI terminals are pretty useful with microcontrollers.
