Gemfan Escape programming
Has anyone used a programmer to program Gemfan 30A escapes from Parallax?
There used to be a card that came with the ELEV-8 V2 kit - but I don't see it in the store.
Is there a standard USB linker that works with these escapes?
Any hints will be appreciated.
Thank you.
Thank you.
This one:
https://www.parallax.com/product/750-90000
I was hoping to find specifics about a card or USB linker that would talk to these Gemfan ESCs -- I checked the Gemfan website - no joy.
Only reference I've found is that Parallax once sold a card that could program them.
The easiest way to do it is to get an Atmel chip socket flasher and use it with a USBASP. I just did this a few weeks ago. If I had to do it all over again, I would have just bought Blheli_S or Blheli_32 ESCs to start with, but all things in life are a learning curve and I didn't know what I was dealing with, just getting started in the hobby.
How many of these ESCs do you have? How many do you need flashed? Maybe I can help out.
https://forums.parallax.com/discussion/154854/open-propeller-project-4-program-our-escs-with-a-propeller/p1
But, if I was going to do it over again, I wouldn't have spent the money on the USBASP, Atmel chip socket flashing tool and the yellow ESCs to begin with. Oh well, live and learn. They do work now, that's a plus.
Maybe I should send Parallax the tools, they can flash SimonK on their pile of HW30 ESCs and at least get them sold to clear out the old inventory! :cool:
Thanks for the offer of help - I'm not building a multi-rotor - I'm trying to learn about ESCs and motors.
I've got a 3DR Solo - motors are noisy. I'm trying to build a motor testbed and see if I can improve them. I'm using an external PWM source.
My first attempt has failed - the motor didn't move. PWM signal is solid - in spec.
I had the old HW30 escapes (couldn't resist a bargain?) - wired it up with a Spectrum receiver - trying to start with a working system. Needless to say - it didn't work - these ESCs hadn't been programmed (wishful thinking).
I tried the BLhelisuite program along with a USB adapter - but it wouldn't talk to the ESC.
Yep - learning curve for sure. I did find the TURNIGY BESC PROGRAMMING CARD (what Parallax used to sell) at Hobbyking for $ 6.28 - (and an $11 ESC).
I'd like to put that firmware on these escapes -- does it take that programmer to do it?
I'm using these old HW30A ESCs on a "V2.5" build I'm getting running with the Parallax Elev-8 Flight Controller and a mix of V3 & V2 parts. They do actually work alright now, but only after flashing SimonK firmware on them. The Atmel socket tool is like $29, and the USBASP is another $9 or whatever, plus purchasing the ESCs...so really, it's not much of a deal unless you're going to flash a ton of them.
Edit: I'll just PM you to see if I can help w/ the socket tool or ESCs, or anything, that'll be easier. :thumb:
Thanks for that link - I'd passed over it last year and forgotten about it. This material can probably round out my education about ESC programming. I can really use it.
