When is a lock needed? — Parallax Forums
My goal is to digitally control the position of a robotic arm that has five DC motors. The idea is to place potentiometers at pivot points along the arm and control them with another set of potentiometers.
I wrote my first PASM object so I could control multiple motors with one cog. The problem is the object seems to hang at odd times.
Ultimately I want to control the arm wirelessly using a controller that mirrors the arm instead of using joysticks.
  • Post your code.
  • evanhevanh Posts: 16,070
    An active lock tells you not to access certain shared space for an unknown length of time. A lock serialises activity in normally concurrent environments. This is not very conducive to parallel motor control.
    I've never used one myself. I think they are mostly used for common system resource allocating schemes.
    Whatever the problem is, a lock is unlikely to help you.
  • If your code "locks up" I guess then it doesn't need a lock :)
    I've never ever needed locks and never used them but recently I had some code from one cog conflicting with a common resource on my main cog. At first glance it looked like it needed a lock around that part of the code to keep it atomic but I hated the idea of that. I solved the problem by using a different method that avoided conflicts in the first place and the code is better and faster.
  • I only have code to tweak the first two motors. If the problem is because I didn't set the clock speed for every cog then I admit I didn't even check for that possibility until Phil said to post my code.
    Even so, the PASM object probably has 'beginner' written all over it.
    lardom wrote: »
    The cogs all run at the same speed, that which you set at the beginning of the code with the clkmode and xinfreq statements.
