' BUTTON.BS2
' Connect an active-low circuit to pin P0 of the BS2. When you press the
' button, the DEBUG screen will display an asterisk (*). The program, as
' shown below, will print an asterisk at the first button press, then
' delay approximately one second (200 x 5 ms PAUSE) before auto-repeating
' at a rate of approximately 100 ms (5 x 20 ms). Feel free to modify the
' program to see the effects of your changes on the way BUTTON responds.
' {$STAMP BS2}
' {$PBASIC 2.5}
Btn PIN 0
btnWrk VAR Byte
Main:
' Try changing the Delay value (255) in BUTTON to see the effect of
' its modes: 0 = no delay; 1-254 = varying delays before auto-repeat;
' 255 = no auto-repeat (only one action per button press)
' The BUTTON instruction will cause the program to branch to
' No_Press unless P0 = 0
https://learn.parallax.com/tutorials/language/pbasic/whats-microcontroller
There is a free PDF book you can download which seems to cover your question.
https://www.parallax.com/downloads/whats-microcontroller-text
' {$STAMP BS2}
' {$PBASIC 2.5}
Btn PIN 0
btnWrk VAR Byte
Main:
PAUSE 5
BUTTON Btn, 0, 200, 20, btnWrk, 0, No_Press
DEBUG "*"
No_Press:
GOTO Main
Take a look at the above...This demo just shows how to do it, You real code will only be one or two short lines.$WMc% out
