Not able to get cog_run to run code
So, I'm attempting to create a animated display using a Parallax 96x64 OLED Display Module and a FLiP and what I would like is to be able to update the screen from a function that runs in another cog. The code I have which is written in 'C' using SimpleIDE works fine when not running in a separate cog, but when I try to run this same code using 'cog_run' or 'cogstart' the OLED update does not occur. I've added a simple blink LED code fragment in the mix and the LED on the FLiP blinks as expected even when the function is run in a separate cog butt the OLED update does not occur from 'cog_run' or 'cogstart'.
I've tried to increase the stack size and the OLED code still will not run even with a stack set to 4096.
The code and libs I am using as an example came from the following link:
https://parallax.com/downloads/96-x-64-color-oled-display-propeller-c-code
It all works just fine without trying to run in a separate cog so It just baffles me as to why the code to update the OLED does not update.
Any suggestions would be most appreciated.
This is the code I am trying to run in a separate cog.
NOTE: This was borrowed from the 'oled_shapes_examples.c' example.
#include "simpletools.h" // Include simple tools
#include "oledc.h" // oledc library
// Define communication pins withing init function oledc_init().
#define SID 6 // Serial data in.
#define SCLK 7 // Clock
#define CS 8 // Chip select.
#define RS 9
#define RST 10
#define SCRN_ROT 2 // Screen rotation chosse between 0, 1, 2, 3,
unsigned int stack[512];
int *cog;
void snowBalls();
int main() // Main function
int i = 0;
oledc_init(SID,SCLK,CS,RS,RST,SCRN_ROT); //Initiate SPI communication.
oledc_clear(0,0,oledc_getWidth(),oledc_getHeight());//Clear entire screen.
//cogstart(snowBalls, NULL, stack, sizeof(stack));
cog = cog_run(snowBalls, 128); // Does not run oledc code
while(1)
//snowBalls(); // Runs oledc code fine when running normally
pause(500);
print("Cog0 is running\n"); // This gets displayed when running 'cog_run' or 'cogstart'
//Draw and fill in in circles.
//void snowBalls(void *par)
void snowBalls()
#define MAXSBS 6
int aSize = 0;
int yUpdate[MAXSBS] = {5, 8, 11, 15, 12, 10};
struct sbVal {
int x0;
int y0;
int r;
int sbColor;
struct sbVal sb_vals[MAXSBS] = {
{5, 5, 2, WHITE},
{15, 10, 1, WHITE},
{20, 25, 2, WHITE},
{75, 15, 1, WHITE},
{82, 12, 2, WHITE},
{91, 17, 1, WHITE}
//print("In Cog1 to pring snowBalls\n");
while(1)
for(int i = 0; i < MAXSBS; i++)
oledc_fillCircle(sb_vals[i].x0, sb_vals[i].y0 , sb_vals[i].r, sb_vals[i].sbColor);
//print("In Cog1 to print snowBalls\n");
high(26); // LED on
pause(100);
low(26); // LED off
//pause(100);
pause(500);
oledc_fillCircle(sb_vals[i].x0, sb_vals[i].y0 , sb_vals[i].r, SKYBLUE);
if(sb_vals[i].y0 > 75)
sb_vals[i].y0 = 0;
}else{
sb_vals[i].y0 += yUpdate[i];
Ah, awesome! I knew I was missing something.
I moved "oledc_init" to the snowBalls function and it works perfectly now.
Thanks a bunch!
