Incomprehensible behavior on inclusion of an object
human
in Propeller 1
Dear all,
My program is written in PASM/SPIN and works the way I want it to.
The OBJ section of the main file looks like this:
Now, when I include another object:
The program is no longer working as intended. Please note that the object 'demo' is not used anywhere in the code. It's only listed in the OBJ section. The size of the .binary increases from about 8KB to 13KB after I include this line.
Is the object used/executed in some way only because it's listed in the OBJ section?
Does anybody have an explanation for this given this black box example?
Thanks!
OBJ debug: "SerialMirror" fmt: "Format" aescontroller: "HubAES" hmaccontroller: "SHA-test"
OBJ debug: "SerialMirror" fmt: "Format" aescontroller: "HubAES" hmaccontroller: "SHA-test" demo: "Demo"
Thanks!
After reading your reply I've double-checked all PASM loops and it turned out that there were a couple of memory-related mistakes. Apart from that, I forgot to clear some "res" memory.
The problem is solved. Thank you!
