pairing arduino and a propeller
Has anyone paired an arduino uno board with a propeller. I am thinking of using an arduino uno board to create "chameleon" type board. Can the arduino board power a propeller dip and serial memory chip?
I tried using serial communication between them but had issues since I was using the Pro Mini's hardware Serial port which is also used to program it.
You mentioned the Chameleon AVR. The manual to it could give you a few ideas which can be downloaded at ic0nstrux.com/chameleon-avr-8-bit-system.
BTW I have the Chameleon PIC which is a fun board to use.
Jim
