Is there a Spin equivalent of C structs? — Parallax Forums
I'm considering a wireless, Prop-to-Prop project and would like to pass a bunch of info, by sending one packet. I've got this going in 'duino C but the Prop has obvious advantages.
A search of previous forum discussions didn't seem to turn anything up. Ideas?
    Nope.
    You can perhaps create your packets in arrays and define some constants that are the offsets of items within the array.
    edited 2017-06-01 12:36
    Cspin handles structs in Spin by using offsets, and accessing elements with either BYTE[], WORD[] or LONG[] depending on the size of the element. Cspin translates the following C code
    typedef struct TestS {
        struct TestS *next;
        char *name;
        int size;
        short value;
        char flags;
    } TestT;
    TestT x;
    void sub1(void)
        int i;
        i = x.next;
        i = x.name;
        i = x.size;
        i = x.value;
        i = x.flags;
    to this Spin code
    CON
    ' typedef struct TestS
    next_0 = 0
    name = 4
    size = 8
    value = 12
    flags = 14
    VAR
      long x[4]
    PUB sub1 | i
      i := long[@x + next_0]
      i := long[@x + name]
      i := long[@x + size]
      i := ~~word[@x + value]
      i := byte[@x + flags]
  • maccamacca Posts: 1,059
    Jeff Haas wrote: »
    If you have the code in C already, why don't you try to port it to PropellerGCC ?
  • I think the way large sections of data are used in Spin is to pass the address of the data.
    Dave Hein's post shows a good example.
    Parallax put out an appnote on this topic. Here's a link to the document and sample code.
  • Duane
    Thanks for the appnote link.
  • I recently finished a commercial project that uses XBee in API1 mode with fixed-length packets. I created a template packet in a DAT table and a couple support methods to handle placing the data in it, updating the checksum, and pushing out the serial port. Easy-peasy.
    edited 2017-06-01 19:21
    I'm with Jon on this one. Here is an example structure. In this case it needed to transmit payloads of 100 bytes in API mode for 802.15.4 xbees. The structure includes the $7e for the start of the packet and is initialized with various configuration options. Some advantages to having it in DAT are that you can initialize the data at compile time, and you have good control over the arrangement of bytes, words and longs. The application fills in the payload over time, and the xbee transmissions boil down to sending the 105 byte string starting at "hey". In this case, the structure was written into the main program, but in other use cases I've had it written into a separate object with methods to set and get the contents.
    ' The following structure should be word aligned.
      hey         byte $7e                                  ' start for packet
      length1     byte 0                                    ' MSB of the length
      length0     byte 105                                  ' packet length is 100 plus 5 starting with the byte after this one
      apiTXid     byte $01                                  ' API transmission identifier
      frameID     byte 1
      dest1       byte $ff                                    ' destination short address msb
      dest0       byte $ff                                    ' destination short address lsb
      options     byte $4                                   '
      fwv         byte VERSION
      startTime   byte 0,0,0,0,0                            ' mhdmy
      stopTime    byte 0,0,0,0                              ' mhdmy
      giraDayCode byte 36                                   ' code for length of giraDay in minutes (code 36=1440 minutes)
      giraWeek    byte 7                                   '  Gira interval (week) setting in number of giradays
      weekCount   byte 0                                   ' number of giraWeeks logged so far during this deployment
      C_thresh    byte 50                                  ' temperature threshold in units of 0.1 degreec C
      P_thresh    byte 15                                   ' percent of samples above temperature threshold that qualify as used for day
      volts       byte 0                                    '  battery condition, units of 0.1V
      deltaC      byte 0                                    ' temperature differential
      maxC        byte 0                                    ' maximum delta T during this deployment, resolution of 0.5.
      percent     byte 0                                    ' percent of samples above threshold total during this deployment
      days        byte 0                                    ' total days above percent threshold during this deployment
      pcnt1       byte 0                                    ' percent of samples above temperature threshold in the interval
      days1       byte 0                                    ' days used, counts as used if percent of samples is above pcnth
      degday1     word 0                                    ' degree days for the interval.
      '   ... and so on, 100 payload bytes
  • Wow, thanks for all the information! This forum is a great resource.
