SD Card problem [Solved]
I made my own SD card holder and nothing worked. Try every object on the obex, forum, etc. and nothing SD card won't mount. Even tried soldering pins right to the card and nothing. Tried formatting, SD card, micro SD same thing nothing won't mount. Pull-up resistors 10k, 100k no pull-up's and won't mount. Finally I tried different pins on my prop and Wa-lah it worked like a champ. Turns out my P2 pin on my prop was bad. So I tried P5,P6,P7,P8 instead of P0,P1,P2,P3 that is typically used in most examples.
