Weigant Interface Module
Can anyone help me to create a weigant interface module .
Which I need to convert my number plate OCR to weigant format.
Not too clear on what you want to do. It sounds like you want to send the output from an OCR reader and send it as Weigand data. Is that correct, and if so what is the data format from the OCR ?
In any case here are some objects from the OBEX that may be of help.
http://obex.parallax.com/object/500
http://obex.parallax.com/object/501
http://obex.parallax.com/object/549
