Need help with this code. Trying to write/read from eeprom.
in Propeller 1
I think I'm losing my mind over this. I used to be able to make this sort of thing work but now I can't.
I'm using Prop Proto board with AT512 eeprom (64K). I've also tried it on some other boards of mine that use a 64K eeprom.
I get 255 FF on the terminal display.
Help!
Help!
CON
_clkmode = xtal1 + pll16x ' Feedback and PLL multiplier For Ver 2.0
_xinfreq = 5_000_000 ' External oscillator = 10 MHz For Ver 2.0
MS_001 = 80_000_000 / 1_000
EE_SCL = 28
EE_SDA = 29
EE_DEV_ADDR = $A0 ' EEPROM assigments
EE_BASE_ADDR = $8000
VAR
byte credit
OBJ
i2c : "jm_i2c_driven"
term : "FullDuplexSerialDP_1"
PUB start
term.start(31, 30, %0000, 115_200) ' start terminal using PST
pause(1000) ' pause for PST
term.str(string("EEPROM Testing", 13))
i2c.init(EE_SCL, EE_SDA)
pause(1000)
i2c.putbyte(EE_DEV_ADDR, EE_BASE_ADDR, $3F)
pause(1000)
credit := i2c.getbyte(EE_DEV_ADDR, EE_BASE_ADDR)
term.dec(credit)
term.tx(32)
term.hex(credit, 2)
pub pause(ms) | t
t := cnt
repeat ms
waitcnt(t += MS_001)
