Another Attempt at PropWare in SimpleIDE... not sure where I went wrong
DavidZemon
Project Directory: /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/ SimpleIDE Version 1.1.0 /home/david/Documents/SimpleIDE/Learn/Simple Libraries/ /home/david/Documents/SimpleIDE/ Updated on: 2017-02-20 propeller-elf-gcc -v GCC 4.6.1 (propellergcc-alpha_v1_9_0_) propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/hmi/input/scanner.cpp -o lmm/scanner.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/hmi/output/printer.cpp -o lmm/printer.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/hmi/output/synchronousprinter.cpp -o lmm/synchronousprinter.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/serial/i2c/i2cmaster.cpp -o lmm/i2cmaster.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/serial/uart/fullduplexserial.cpp -o lmm/fullduplexserial.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/utility/comparator.cpp -o lmm/comparator.opp propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -c PropWare/PropWare.cpp -o lmm/PropWare.opp propeller-elf-ar rs lmm/SimplePropWare.a lmm/scanner.opp lmm/printer.opp lmm/synchronousprinter.opp lmm/i2cmaster.opp lmm/fullduplexserial.opp lmm/comparator.opp lmm/PropWare.opp /opt/parallax/bin/propeller-elf-ar: creating lmm/SimplePropWare.a propeller-elf-gcc -I . -L . -I /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller -L /home/david/Documents/DocsLink/Programming/PropellerProjects/PropWare/libpropeller/lmm/ -o cmm/SimplePropWare.elf -Os -mlmm -Wall -m32bit-doubles -fno-exceptions --std=gnu++0x -fno-rtti -fno-threadsafe-statics -ffunction-sections -fdata-sections -Wl,--gc-sections SimplePropWare.cpp lmm/SimplePropWare.a -lm -lpropeller -lm /opt/parallax-gcc4/bin/../lib/gcc/propeller-elf/4.6.1/../../../../propeller-elf/bin/ld: cannot find -lpropeller collect2: ld returned 1 exit status Done. Build Failed!
I don't recognize any a library by the name of libpropeller.a... where did this come from? Here's my .side file:
SimplePropWare.cpp PropWare/concurrent/runnable.h PropWare/concurrent/watchdog.h PropWare/filesystem/fat/fatfile.h PropWare/filesystem/fat/fatfilereader.h PropWare/filesystem/fat/fatfilewriter.h PropWare/filesystem/fat/fatfs.h PropWare/filesystem/file.h PropWare/filesystem/filereader.h PropWare/filesystem/filesystem.h PropWare/filesystem/filewriter.h PropWare/gpio/pin.h PropWare/gpio/port.h PropWare/gpio/simpleport.h PropWare/hmi/input/scancapable.h PropWare/hmi/input/scanner.cpp PropWare/hmi/input/scanner.h PropWare/hmi/output/hd44780.h PropWare/hmi/output/printcapable.h PropWare/hmi/output/printer.cpp PropWare/hmi/output/printer.h PropWare/hmi/output/synchronousprinter.cpp PropWare/hmi/output/synchronousprinter.h PropWare/hmi/output/ws2812.h PropWare/memory/blockstorage.h PropWare/memory/eeprom.h PropWare/memory/sd.h PropWare/motor/stepper.h PropWare/sensor/analog/mcp3xxx.h PropWare/sensor/analog/pcf8591.h PropWare/sensor/distance/ping.h PropWare/sensor/gyroscope/l3g.h PropWare/sensor/temperature/max6675.h PropWare/serial/can/mcp2515.h PropWare/serial/i2c/i2cmaster.cpp PropWare/serial/i2c/i2cmaster.h PropWare/serial/i2c/i2cslave.h PropWare/serial/spi/spi.h PropWare/serial/uart/shareduarttx.h PropWare/serial/uart/uart.h PropWare/serial/uart/uartcommondata.h PropWare/serial/uart/uartrx.h PropWare/serial/uart/uarttx.h PropWare/serial/uart/fullduplexserial.cpp PropWare/serial/uart/fullduplexserial.h PropWare/string/staticstringbuilder.h PropWare/string/stringbuilder.h PropWare/utility/collection/charqueue.h PropWare/utility/collection/queue.h PropWare/utility/comparator.cpp PropWare/utility/comparator.h PropWare/utility/utility.h PropWare/c++allocate.h PropWare/PropWare.cpp PropWare/PropWare.h >compiler=C >memtype=lmm main ram >optimize=-Os >-m32bit-doubles >-Wall >-fno-exceptions >-enable_pruning >defs::--std=gnu++0x -fno-rtti -fno-threadsafe-statics >-lm >-create_library >BOARD::ACTIVITYBOARD
Remove that folder (or compile from a directory with only PropWare sources) and you should be fine.
I don't know if there is a way to force-skip that feature.
