Controlling Disney Magic Ears with the Parallax Badge
ke4pjw
in Propeller 1
This is a project that I put off for 2 years. Last month, I was able to spend some time to get it rolling.
zip
63K
Now I'm wondering what else can be controlled by a wondering badge.... Ha! Lot's of evil ideas !!!!!
Wall of TV's at the local department store! Nudge all the channels as you wonder past.......
Please please make a video as you wander the Magic Kingdom!
GWTS Protocol (2400 baud over IR) Information
http://doityourselfchristmas.com/forums/showthread.php?25142-Glow-with-*OUR*-Show-and-MSP430G2553-discussion&p=257733#post257733
http://doityourselfchristmas.com/forums/showthread.php?25142-Glow-with-*OUR*-Show-and-MSP430G2553-discussion&p=259733#post259733
http://doityourselfchristmas.com/forums/showthread.php?25142-Glow-with-*OUR*-Show-and-MSP430G2553-discussion&p=259750#post259750
http://doityourselfchristmas.com/forums/showthread.php?25142-Glow-with-*OUR*-Show-and-MSP430G2553-discussion&p=259782#post259782
http://doityourselfchristmas.com/forums/showthread.php?25142-Glow-with-*OUR*-Show-and-MSP430G2553-discussion&p=259872#post259872
I haven't worked with this in a long time, and as my GWTS ears are on a shelf just a few feet from my desk, I may have to put a fresh set of batteries in and start playing again
https://disneyworld.disney.go.com/destinations/animal-kingdom/pandora-world-of-avatar/
I know it's East Coast, but they like your work.
Don't! I used to have a TV-b-gone and would switch off all of the TVs in the local shop. I forgot that IR shows up really well on CCTV!
I was happy with the results, not as impressive as I imagined, but there is time to create a better rig. I must say that the badge platform is pretty darn awesome to develop on.
I think my wife may have taken some video (my phone had died). If it is good, I will post it.
That would be awesome! Could totally work too! After a minute or so, the ears go back to random light sequences. Just add a lens to focus the beam. Easy!
I directly drove them off of the battery and switched them with a generic NPN transistor I got from Radio Shack. IC was rated at 800ma IIRC. Worked pretty good! I found that I could overdrive the LEDs when they are modulated, so 3.7V wasn't a problem
I do recall changing that. I believe I changed it to 38Khz.
I thought I posted source code here. I will post it this evening.
P17 sends a reset packet.
P26 sends a reset packet then walks through a sequence of primary colors in a loop.
P27 strobes.
Hold down P17 before changing between P27 and P26 modes.
Please pardon the code. I butchered Jon's awesome code.
The modules that I had to modify are marked tt_ instead of jm_. I had to set 2 stop bits in the TX portion.
Very cool Terry, and kudos to Jon for the heavy lifting.
https://sites.google.com/site/listentoourlights//home/how-to/glowwiththeshow/hacking-gw
I am looking at this lookup table to create DMX to GWTS mappings.
https://github.com/Materdaddy/GwtS-Arduino/blob/master/GwtS.cpp
I have had a lot of fun with this project.
Thanks Terry.
var byte txpin long bittix pub setup_ir_serial(pin, baud, modfreq) txpin := pin bittix := clkfreq / baud outa[txpin] := 0 dira[txpin] := 0 ' no modulation until ready ctra := (%00100 << 26) | txpin frqa := ($8000_0000 / (clkfreq / modfreq)) << 1 pub irtx(c) | t c := ((c | $F00) << 2) ^ $FFF ' add start and stop bits t := cnt ' sync to system clock repeat 10 ' start + 8x data + stop waitcnt(t += bittix) ' wait bit time dira[txpin] := c >>= 1 ' output next bit (LSB) pub irtx_buf(p_buf, len) repeat len irtx(byte[p_buf++]) var byte gwtsbuf[18] pub tx_gwts9x_command(p_cmd, len) '' Format and transmit GwtS 9x command '' -- p_cmd is pointer to command bytes (sans 9x header and checksum) '' -- len is bytes in command, 1..16 gwtsbuf[0] := $90 | (len-1) ' set header with length bytemove(@gwtsbuf[1], p_cmd, len) ' copy packet to tx buffer gwtsbuf[len+1] := crc8x(@gwtsbuf, len+1) ' add checksum irtx_buf(@gwtsbuf, len+2) ' send it pub crc8x(p_src, n) : crc | b '' Returns CRC8 of n bytes at p_src '' -- implementation by Micah Dowty repeat n b := byte[p_src++] repeat 8 if (crc ^ b) & 1 crc := (crc >> 1) ^ $8C else crc >>= 1 b >>= 1
