Anyone have TSL1401R-LF chips they don't need?
Phil Pilgrim (PhiPi)
Well, this worked for Tracy, maybe it'll work for me. Like Tracy, I've found the aftermarket dealers to be blood-sucking scoundrels -- although he stated it more politely.
Anyway, I need up to 22 ea. AMS/TAOS TSL1401R-LF linear array sensor chips to use in the rest of some partially-assembled TSL1401-DB modules. These are the lead-free 8-pin DIP versions that have been EOL'd for awhile now.
I already have new-design modules in stock that use the SMD version of the chip, but it would be nice not to let any of the older boards go to waste.
I checked my parts from some linear arrays and I found two TSL3301 LF chips but of course these aren't quite the same.
Good luck with your search.
Today I was informed by Mouser that the surface-mount version of the chip, the TSL1401CL, that I've designed into the new version is "not recommended for new designs." This is usually a precursor to an EOL. I've already purchased 500 of them, which are now soldered onto the new modules. But I have another 500 bare PCBs without chips to populate them, and the chips are not cheap. Not sure what to do. I've put a query into AMS's support line regarding future availability. If I have to, I'll buy another 500 right now; but, geez! this is starting to get expensive. Nonetheless, I'm committed to the product and will do whatever I have to to keep it in the pipeline.
What Mouser says about parts needs to be verified by the part maker, in this case AMS.
