RXD and TXD 150 ohm series resistors on the Prop Plug and Prop Clip
I am assuming the 150 ohm series resistors for RXD and TXD on the Prop Plug and Clip are there to protect the FTDI232R pins from being connected to something they shouldn't be connected to. Otherwise, if the FTDI232R (or the FTDI231X for that matter) were on the same circuit board as the prop the series resistors wouldn't be needed.
Just checking....
Kevin
Just checking....
Kevin
For the same reason, it would be advisable to include those resistors on the same board, unless other buffering options were utilized.
