Erco: Standard size DC-operated CR servos?
GordonMcComb
in Robotics
Erco, my fine scavenging friend, what are the options for standard size CR servos that are direct-DC connection (rather than servo signal)? I know you have some that are mini/micro, but anything with more torque?
Yes, I know regular servos can be readily hacked to connect directly to the motor, but I'm looking for something factory-made.
Will poke around when I have more time and advise if I find anything. I'm busy lasering at moment.
You're likely already familiar with Dagu's Little Black Duck motors.
Dagu also sells these with small wheels. (Edit: Apparently the ones with the wheel include the servo electronics.)
Good luck in the search.
Not cheap... Dimensions are 50x20x55mm so it's not a 9 gram.
https://solarbotics.com/product/gm4/
https://www.pololu.com/product/2367
There must be a market for a DC motor in a standard servo case, because many of us have been looking for years. But it needs to be cheaper than the alternatives that are actually better motors. Strangely enough, the makers don't seem to be supplying that market, or want too much for them.
The imported yellow case motors (using the Solarbotics GM2/3 form factor) generally lack quality control, or they'd be just right.
Surely you jest.
http://www.ebay.com/itm/DC-6V-30RPM-Mini-Metal-Gear-Motor-Gearwheel-Model-N20-10mm-Shaft-Diameter-MY-/360897904681
https://www.alibaba.com/product-detail/N20-3v-6v-dc-micro-metal_60159974835.html
In the true spirit of Christmas, Beau has shamed us all...
JK, you ROCK, Beau! Merry Christmas, now when are we having drinks on the Queen Mary again?
Jim
That's probably it, erco didn't comment. He was busy grabbing the lot @ $1.13 / piece.
Free amplifier with each order. Won't last!
No, it means $1 is the unit price at the (high) quantity they may or may not quote in the listing, and $13 is the sample price.
As usual, for my application, I can't rely on direct-from-China sources. It changes too often and becomes obsolete before I can get the information into the hands of consumers.
Thanks for the enlightenment.
Jim
