Drone Rescue
geo_leeman
in Robotics
Hey guys,
I've had a look around at the various drone rescue (i.e. parachute) systems, such as those from MARS. I'm thinking of a similar design, but with an ESC feedthrough for each motor. In the even the parachute is needed, we would ground the ESC signal wires to stop the rotors to reduce the chance of the parachute getting shredded. I was wondering if there were any thoughts about using a transistor and pull-downs to stop the motors? I haven't had a good play with the ESCs yet, but given what I've read, it seems like that could be a reasonable solution.
For the curious, I'm thinking of deploying a parachute when these conditions are met:
1) System is activated with an AUX channel on the remote (done at takeoff to get a zero pressure for the ground level).
2) Vehicle is above 5-10m so parachute has time to do something.
3) Vehicle is in free fall (accelerometer detection) or rotation about any axis is greater than a threshold TBD.
Sorry just seeing this now. Can you explain a little more about what you mean by this (I know what you mean by pulling the signal low)? Do you mean do we have issues of that happening unintentionally when we don't want it to? Or do we do ever do it intentionally? Or something else?
