Full Duplex Serial object with >256 byte buffer? — Parallax Forums
I'm looking for a serial object with a buffer of more than 256 bytes. I've been using FullDuplexSerial_rr004 which said it could do 512 bytes when I downloaded it, though the OBEX now [correctly] says it can't. I only need 9600 baud, though it needs to be able to run at 5MHz, so I'm not sure if a SPIN object could handle that.
    edited 2016-11-16 02:18
    Use the 4-port serial driver from the OBEX. It's tested with 4 115K ports with a 6MHz crystal so it should do just fine with a single port and a 5MHz crystal. You can easily change the buffer sizes for each of the 4 possible ports. There's a single equate for the size of each ports' RX and TX buffer. Read the comments in the source for details.
  • Mike Green wrote: »
    Thank you. I will give that one a try!
  • I reread the comments in the source. The 4x115K with 6MHz crystal is with a 96MHz system clock (PLL=16x). The maximum Baud with an 80MHz system clock is 750K for a single port. You want to use a 5MHz system clock to save power. 80MHz / 5MHz = 16 so you should be able to get 750K / 16 = 46K (roughly) which is well in excess of what you need. Phil's driver also has handshake options and less jitter than the "standard" FullDuplexSerial.
  • Thanks. I'm probably going to strip the object down a fair bit too. I only need one port, and the 2.7kb price tag is a bit high for our application.
    edited 2016-11-17 21:11
    If you want to continue with FullDuplexSerial_rr004, I think it is not too much effort to modify that so it can support whatever buffer size you need. Easier than messing with the 4-port object. It doesn't appear that you need the flow control options.
    In FullDuplexSerial_rr004, in the pasm code, change two lines.
    line 250 is now,
    and     t2,#bufmsk
    change to
    cmpsub     t2,#bufsiz
    same thing for line 272, now
    and     t3,#bufmsk
    change to
    cmpsub     t3,#bufsiz
    Then in the spin code, change all 3 instances of
    & bufmsk
    to
    // bufsiz
    That is in lines 93 (rxcheck) , and lines 117 and 119 (tx(txbyte))
    Note that bufmsk is no longer used.
    Change bufsiz to whatever value you want. It does not have to be a power of two. As written, the rx and tx buffers are the same size.
    The magic is performed by the cmpsub operator, conditional subtract that wraps the pointer back to the start of the buffer.
  • If you want to continue with FullDuplexSerial_rr004, I think it is not too much effort to modify that so it can support whatever buffer size you need.
    Thanks! Worked like a charm. The new limit with these changes is 511 bytes, but that's fine for what I'm doing. I'll further modify it to separate the buffer sizes, because my tx buffer can be tiny. I only need the larger buffer for incoming messages.
    edited 2016-11-18 05:59
    If you want to grab a larger chuck of free memory, the cmpsub instructions would have to reference a register rather than a literal constant.
    not... cmpsub t3,#BUFSIZ
    but... cmpsub t3,bufsiz ' where bufsiz is a register that has been initialized with a value
    Can also easily have separate rx and tx buffers. One way to do it,
    'snippets...
    CON
      BUFSIZRX = 1000     ' for example
      BUFSIZTX = 20
    DAT
      rxsize long BUFSIZRX     ' these are default buffer sizes from the CONstants
      txsize long BUFSIZTX     ' loaded into the pasm cog
      ' then follow with the res variables
      t1 res 1
      ' etc.
    ' In the PASM ...
    line 204...  add     txbuff,rxsize     ' was add txbuff,#bufsiz, note that txbuffer follows immediately after the rx buffer in the hub
    line 250...  cmpsub     t2,rxsize     ' value in a register can exceed 511
    line 272...   cmpsub     t3,txsize
    and the obvious changes to the spin code in lines 93, 117 and 119.
    edited.
