Si1143 Gesture Sensor.
                                  in Accessories
                      I got the Si1143 out and was going to play around with it. But I am confused by the quick-start guide (page 2) in the paralax PDF it says to wire up like the diagram. Under the popeller paragraph says
For the Propeller P8X32A, Vdd is 3.3 VDC, and The microcontroller pins P0, P1, and P2 match the
Propeller I/O pins used in the Spin example code.
The stamp says
For the BASIC Stamp 2, Vdd is 5 VDC, and R is 4.7 kΩ. The microcontroller pins P0 and P1 match BASIC
Stamp I/O pins used in the PBASIC example code. Omit the P2 connection to the device’s INT pin.
It does not give any resistor Info for the propeller. Does it not need it because VDC is 3.3 V? Or if it does what value should they be?
The stamp says
I'll keep you updated.
{{ File: Si1143.spin Version: 1.1 Date: November 19, 2012 Typical Connection Diagram: VIN = 3.3V ┌──────┐ ┬ ┬ ┬ ┬ ┌────────────────┐ │ │ │ │ │ │ │• [‣] •│ │ │ R R R ┌─┼─┤GND │ │ │ │ │ │  └─┤VIN ┌─────────┘ │ Px├───┻───┼───┼────────┤INT │ │ Py├───────┻───┼────────┤SCL │ │ Px├───────────┻────────┤SDA │ │ │ │• │ └──────┘ └──────┘ Propeller MCU Si1143 Proximity (P8X32A) Sensor (28046) R = 4.7kΩ Px, Py, Pz = Any desired Propeller I/O pins }}Pullup resistors on I2C devices is SOP.
https://learn.sparkfun.com/tutorials/i2c/i2c-at-the-hardware-level
"Unlike UART or SPI connections, the I2C bus drivers are “open drain”, meaning that they can pull the corresponding signal line low, but cannot drive it high. "
Thanks very mush for the help.
