ActivityBot COM Port Not Connecting — Parallax Forums
So after getting my ActivityBot, I downloaded SimpleIDE and the drivers from the tutorial. I then followed the instructions to try and run a program, but when i went to select my bot from the dropdown menu in the upper right corner, it wasn't there. I looked at the troubleshooting guide online, but it said to just unplug it and plug it back in, which did not work even after about 30 attempts. I tried re-installing the drivers, and SimpleIDE, but nothing has worked. So does anyone know what I can do? Thanks?
P.S.
I'm using macOS Sierra 10.12.1 on a 13-inch MacBook Pro
I downloaded the v2.3 drivers from the website link on Parallax
I downloaded SimpleIDE 1.0 RC2 from Parallax as well
I'm connecting via a new USB to Micro-USB cable included in the kit
The board is new and has power, and the power switch is in position 1
  • dgatelydgately Posts: 1,647
    edited 2016-11-07 14:46
    To verify that the driver is actually seeing the ActivityBot, try the following command in the Mac's Terminal app, while the ActivityBot is connected to your Mac via USB.
    ls /dev | grep usb
    You should see something like one of the following:
    ls /dev | grep usb
    cu.usbserial-00002014
    tty.usbserial-00002014
    OR:
    ls /dev | grep usb
    cu.usbserial-DAWIJ6AJ
    tty.usbserial-DAWIJ6AJ
    If you don't get this kind of response, the FTDI driver is not working.
    Note: Mac OS X Sierra already contains a generic FTDI driver that should have seen the ActivityBot without installing drivers from FTDI's website. It' possible that there is a contention with your downloaded FTDI driver...
    dgately
  • Mr. LewisMr. Lewis Posts: 24
    edited 2016-11-08 18:27
    I am running macOS Sierra and haven't had any problems recently. One question, have you rebooted your computer since installing the drivers/program? Sometimes the USB drivers will hang and none of the mac versions will work correctly after this - its really bad with MacBS2. This is a driver issue from what I have read and sometimes rebooting your Mac will fix the issue.
    The problem normally isn't bad with SimpleIDE, but could be the issue for you, otherwise, try a different cord or USB port on your mac just to see.
    If you still can't get it to work, not sure what else to suggest, but I can tell you it should all work with no problems.
    PS. Is your green light on for the Activity Board - it should come on when plugged in and switched to 1 even when you do not have batteries. If the light isn't on then this is a good indication that your USB is probably frozen.
