Prop C3 FLASH 1MB test failed
in Propeller 1
Hello,
I just realized that my recently purchased Prop C3 board fails the FLASH 1MB test (Writing).
But I also read in the "33209-Unleashing-Propeller-C3v1.0.pdf" book that some versions of C3 may ship with a flash memory chip from different manufacturers and thus may require corrected driver.
I use the demo suite from the Parallax FTP site: ftp://ftp.propeller-chip.com/PropC3/Sources/prop_c3_unit_test_010.spin
Any suggestions? Should I request the board to be replaced on warranty?
Marek
Marek
Never mind guys, I apparently loaded older version of the test suite.
When I loaded: ftp://ftp.propeller-chip.com/PropC3/Sources/c3_unit_test_010.spin
the flash 1MB test passed.
Marek
Thank you.
I tried VGA version.
I experienced following problems:
1) Previously saved BAS program on SD card loads, but produces: "Error while loading file". Other than the message, program loads just fine and can be executed. Note that the original TV version of FemtoBasic doesn't have the problem with the same file or any file saved from this VGA version with flash support.
2) I could save to flash with colon prefix: SAVE ":hello2.bas", but:
* file name must not exist on SD card (why?) or it just doesn't save. I tried to SAVE ":hello.bas" while I had the file with the same name on SD card. Did not save to flash. No error message.
* could not load with LOAD ":hello2.bas"
* when tried to save another program to flash, got error "Can't create flash file" and flash content was destroyed (no files). From this moment on I could not save anything to flash. Even after I reloaded C3 Femto Basic to RAM, I am still getting "Can't create flash file". The flash memory test passes though in C3 test suite.
NOTE: After I erased first 16 kB of flash using erase command in Femto (erase 0:erase 1, erase 2, erase 3), I was able to save files again. However issues #1 and #2 still stand regarding other problems (error message and duplicate file name across SD and flash storage).
Marek
I'll see what I can do about these bugs.
I don't really need FemtoBasic right now, working on my own project and just exploring Propeller chip.
I just provided the information about these problems FYI.
Thanks!
