ELEV8 Ground Station XBee Bracket
geo_leeman
in Robotics
I thought that some people might find this useful. I decided that my ground side radio for the ELEV8 needed a bracket so it wasn't flopping around. I wanted to have access to the solder terminals and be able to change the radios out for reprogramming purposes. Anyhow, I designed up a little bracket with a clip in OnShape and printed it. The hardware is 4-40 and the nuts are a tight press fit so they won't fall out. I've attached the STL files, but you can copy and alter the design from here.
Any feedback welcome! Hopefully someone else finds this useful in their robot/drone adventures.
