Dumb Spin question — Parallax Forums
Dumb Spin question
David BetzDavid Betz Posts: 14,530
edited 2016-10-18 16:40 in Propeller 1
Can the || (absolute value) operator ever return a negative number? I'm thinking of the case where the input value is the largest negative number $80000000. If you negate that you get the same value back. Will the || operator do that and return a negative value for that case?
Edit: Maybe it would be good if I describe what I'm trying to do. I want to generate a random number between 0 and n-1 and am trying to do it like this:
  x := ||?seed // n
However, I'm afraid that if ?seed returns $80000000 then I'll get a negative result.
  • Hmmm... Now that I think of it, maybe this would do the trick:
      x := ||(&seed // n)
  • Yes, || $80000000 would give a result of $80000000. It uses the absolute value instruction which conditionally does a negate based on the sign bit.
  • signed values are represented in two's compliment form hence, the "largest" negative value is actually $8000_0001 (-2147483647) and the largest positive is $7FFF_FFFF (2147483647); the value $8000_0000 is actually a minus ZERO (sign meaningless)
    hope this helps
  • mmowen wrote: »
    hope this helps
    Thanks although I thought that minus zero was actually a concept from one's complement notation. Anyway, I thought maybe Spin did something to take care of that case but I guess it doesn't.
  • ElectrodudeElectrodude Posts: 1,686
    edited 2016-10-18 18:03
    Instead of using "||?seed // n", why don't you use "((?seed) & $7FFF_FFFF) // n"? Simply masking out the sign bit will always return a non-negative value.
    mmowen wrote: »
    hope this helps
    It's not a minus zero, it's -2147483648. There's no such thing as minus zero in two's complement arithmetic. It isn't adjacent to any numbers remotely near zero. It could be either -2147483648 or 2147483648, since it's adjacent to both -2147483647 and 2147483647, but the standard interpretation is that it is negative because numbers with their top bit set are negative.
    I ran the following C program on my computer with no optimization, and it printed out -2147483648 twice:
    #include <stdio.h>
    int main(int argc, char **argv)
            int x = 0x80000000;
            printf("%d\n",  x);
            printf("%d\n", -x);
            return 0;
    edited 2016-10-18 18:08
    As long as n is small w.r.t. the largest positive number, your results using the // operator will be relatively unbiased. Where you get into trouble with larger n is when the ? operator returns a number as large as, or larger than, the largest multiple of n that fits in 31 bits. You can eliminate this bias by determining what that largest multiple is, then throwing out ? results that are at least as large before applying the // operator.
  • Instead of using "||?seed // n", why don't you use "((?seed) & $7FFF_FFFF) // n"? Simply masking out the sign bit will always return a non-negative value.
    Thanks. Yes, that would probably work as well as my second suggestion of using ||(?seed // n).
  • JonnyMacJonnyMac Posts: 9,777
    edited 2016-10-18 20:22
    I use a variant of Heater's random object and when I want a positive value I tend to do this.
      value := (prng.random >> 1) // SPAN + MIN_VAL
  • JonnyMac wrote: »
    What is the purpose of shifting right by one? Is the low order bit not random?
  • Shifting right is another way to get a positive value. It requires fewer bytecodes and may be slightly faster than "& $7fffffff".
  • Dave Hein wrote: »
    I thought all values in Spin were signed. Doesn't >> sign extend?
  • ~> does sign extension. >> inserts zeroes.
    You can tell I'm a Spin dunce. Hence the title of this thread. Thanks!
  • mmowen wrote: »
    hope this helps
    Usually worth checking your facts before posting I find.
    Its 2's compl_e_ment, not compl_i_ment and $80000000 _is_ a negative value and is completely meaningful,
    but happens to have no representation of its absolute value in 32 bits.
    https://en.wikipedia.org/wiki/Two%27s_complement
    I would have thought that the opposite would be true, that the & operation would require fewer bytecodes. Can you explain why?
    Walter
    My guess is that shifting is a single PASM instruction that does not require a second long for the $7fffffff bit mask.
    edited 2016-10-19 13:39
    For fun I ran a timing test. AND-ing takes 704 ticks while shifting right by one takes 656 ticks. The latter is faster by 48 ticks (0.6us).
      seed := ?cnt
      t1 := -cnt
      result := seed & $7FFF_FFFF
      t1 += cnt - 544
      term.dec(t1)
      term.tx(13)
      t1 := -cnt
      result := seed >> 1
      t1 += cnt - 544
      term.dec(t1)
      term.tx(13)
    To be fair, result is different given the same seed. For applications where a random value is desired, this is okay. To have the same result using these techniques the shifting variant would have to be changed to:
      t1 := -cnt
      result := (seed << 1) >> 1
      t1 += cnt - 544
      term.dec(t1)
      term.tx(13)
    ...which now takes 992 ticks.
    For grins I opened BST to look at the compiled output:
    64                        result := seed & $7FFF_FFFF
    Addr : 0049:             64  : Variable Operation Local Offset - 1 Read
    Addr : 004A:          37 3E  : Constant Mask Y=62 Decrement 7FFFFFFF 2147483647
    Addr : 004C:             E8  : Math Op &
    Addr : 004D:             61  : Variable Operation Local Offset - 0 Write
    70                        result := seed >> 1
    Addr : 0065:             64  : Variable Operation Local Offset - 1 Read
    Addr : 0066:             36  : Constant 2 $00000001
    Addr : 0067:             E2  : Math Op >>
    Addr : 0068:             61  : Variable Operation Local Offset - 0 Write
    Seems like the speed difference from the original comparison is due to an extra hub read.
  • I love the $37 Constant Mask opcode. It's incredible how many useful constants it can encode in only one data byte.
    Anyway, I agree with JonnyMac that "x >> 1" is faster than "x & $7FFF_FFFF" because the constant 1 is only one byte of PNUT ($36: push 1) while $7FFF_FFFF is two ($37 $3E: push constant mask, Y = $3E). I'll bet the >> and & operators themselves take exactly the same amount of cycles to run.
  • $7fffffff requires 2 bytes and "1" requires 1 byte. Spin has special bytecodes to represent -1, 0 and 1. Normally, Spin would require 5 bytes to represent a 32-bit value such as $7fffffff, but values of powers of 2 and powers of 2 minus 1 can be represented by a special 2-byte code. $7fffffff is equal to "(1 << 31) - 1", and can be represented by the special 2-byte code. The Spin interpreter requires a few extra cycles to decode a 2-byte constant.
  • Thanks for the explanation. I didn't consider the difference in length of the representations of the constants.
    mmowen wrote: »
    hope this helps
    #include <stdio.h>
            int x = 0x80000000;
            printf("%d\n",  x);
            printf("%d\n", -x);
            return 0;
    Try this then just for grins:
    CON
      _clkmode = xtal1 + pll16x                  ' System clock → 80 MHz
      _xinfreq = 5_000_000                       ' external crystal 5MHz
    OBJ
      PST   : "Parallax Serial Terminal"
      SN    : "Simple_Numbers"
    PUB Main | value
      PST.Start(115_200)
      repeat 3
        waitcnt(clkfreq+cnt)
      value := -2147483647 '$8000_0001
      PST.Str(SN.hex(value,8))
      PST.NewLine
      PST.Str(SN.dec(value))
      PST.NewLine
      PST.Str(SN.hex(||value,8))
      PST.NewLine
      PST.Str(SN.dec(||value))
      PST.NewLine
      value := 2147483648 '$8000_000
      PST.NewLine
      PST.NewLine
      PST.NewLine
      PST.NewLine
    I get the following as a a result:
    80000001
    -2147483647
    7FFFFFFF
    2147483647
    80000000
    -0
    80000000
    -0
  • Congratulations, you found a bug in Simple_Numbers.spin! If you look at the source of Simple_Numbers.decstr, you'll see that it first checks if the number is negative, and, if it is, it outputs a "-", negates the number, and continues. There is no special case, like there technically should be due to the fact that -$8000_0000 == $8000_0000. I'm sure at least one of the two very smart authors of that object was aware of the problem but ignored it because he preferred not to add a special case to fix a problem that would almost never happen.
  • The .dec() method in FullDuplexSerial accounts for NEGX.
  • Ensuring that the number is positive is just part of the problem; David also wants to limit it to a range of 0 to n-1. Once you include the // n operator, it seems that the initial solution is fastest.
    The actual amount of time varies depending on what n is, but typically:
    ||(seed // n) executes in ~1408
    seed >> 1 // n executes in ~1568
    seed & $7FFF_FFFF // n executes in ~1616
    edited 2016-10-20 17:58
    That makes sense, since >> 1 takes two bytes (push constant 1, shift right) while || takes only one (abs).
