I2C Problem
in Propeller 2
I have an issue with configuring a PropCam directly from the P2v. Currently, I have a P1 hooked up and all it does is the initialization:)
The initialization is pretty simple and I have transliterated the code directly from Phil's code which appear as comments throughout:
I have highlighted a place in the code, (4 lines from bottom) where it hangs. If I insert a simple delay rather than the Boolean, it returns but the initialization fails.
I must be doing something pretty stupid to mess it up, but for the life of me, no clue:)
Ideas?
PropCam_Initialize mov i2c_delay,##400 'set serial snapshot mov i2c_address,$88 mov i2c_register,#1 mov i2c_setting,%0100_0001 call #_Configure 'set exposure waitx i2c_delay mov i2c_register,#3 'register 3 sets lower byte of _EXP waitx i2c_delay mov i2c_setting, ##_EXP 'set exposure call #_Configure waitx i2c_delay mov i2c_register,#5 'register 5 sets upper byte of _EXP mov i2c_setting,##_EXP shr i2c_setting,#8 call #_Configure ret _Configure setb outa,#_SCL 'outa[Scl]~~ waitx i2c_delay clrb dira,#_SDA 'dira[Sda]~ waitx i2c_delay clrb outa,#_SDA 'outa[Sda]~ waitx i2c_delay setb dira,#_SDA 'dira[Sda]~~ waitx i2c_delay clrb outa,#_SCL 'outa[Scl]~ mov i2c_data,i2c_address 'i2c address call #_Write_i2c mov i2c_data,i2c_register 'which register call #_Write_i2c mov i2c_data, i2c_setting 'register setting call #_Write_i2c setb dira,#_SDA 'dira[Sda]~~ waitx i2c_delay setb outa,#_SCL 'outa[Scl]~~ waitx i2c_delay clrb dira,#_SDA 'dira[Sda]~ waitx i2c_delay ret _Write_i2c {{ This section is Low-level I2C write method from Phil's code: '' '' `Parameters: '' '' `data: byte to write to I2C }} ' repeat 8 ' dira[Sda] := i2c_data & $80 == 0 ' outa[Scl]~~ ' i2c_data <<= 1 ' outa[Scl]~ ' dira[Sda]~ ' outa[Scl]~~ ' repeat while ina[Sda] ' outa[Scl]~ mov i2c_reps,#8 mov i2c_bit,#7 DataByte_Out isob i2c_data,i2c_bit wc setbc dira, #_SDA waitx i2c_delay setb outa, #_SCL waitx i2c_delay clrb outa, #_SCL sub i2c_bit,#1 waitx i2c_delay djnz i2c_reps,#DataByte_Out clrb dira,#_SDA 'dira[Sda]~ waitx i2c_delay setb outa,#_SCL 'outa[Scl]~~ wait5 isob ina,#_SDA wc ' repeat while ina[Sda] if_c jmp #wait5 '<<<<<--------- hangs here waitx i2c_delay clrb outa,#_SCL 'outa[Scl]~ waitx i2c_delay ret
Ideas?
