tranistor
SUERSH
how to calculate base and collector resistor value for transistor bc547 step by step
A simple google search would bring up the information you need.
http://www.daycounter.com/Calculators/Transistor-Switch-Saturation-Calculator.phtml
http://www.petervis.com/GCSE_Design_and_Technology_Electronic_Products/transistor_base_resistor_calculator/transistor_base_resistor_calculator.html
http://electronics.stackexchange.com/questions/21544/determine-suitable-resistor-for-the-base-of-transistor-as-switch-npn
The collector value would be based on your voltage, which you did not provide.
There are hundreds of tutorials around the net about using transistors. See links given above for example.
It kind of depends on your application. What is it you actually need to do?
Did she have the capacity? Could she be induced? Or was she purely resistive?
They probably just need a harder bias 'resister' on their gate.
