PING))) Ultrasonic Distance Sensor - Windows 10 Core IoT
I m really new to Windows 10 IoT.
I wonder if there is someone who has been able to manage the Parallax-Ping using C#.
I m a bit lost and most of the examples I've seen use anoter type of sensor..
Thanks.
Thanks.
I use a Raspberry PI 3 with Windows 10 Core IoT.
Regards.
https://www.parallax.com/product/32230
guruumeditation.net/en/digital-io-with-windows-10-iot-raspberry-pi-2-and-the-ultrasonic-ranging-module-hc-sr04/
However, the basic functionality of the different ping sensors should be the same. Just be sure to pay attention to the pinout on the ping sensor and the specs. For example, looking at the face of the ping sensor (the side that faces out towards and object), the pinout between the Radio Shack Sensor (White one) and the Parallax Ping sensor are swapped.
Here is a post that does a comparison between the Parallax, SainSmart and RadShack Ping sensors using an Arduino board.
theotherandygrove.com/parallax-ping-hc-sr04-review/
