Hooking up Potentiometer to Servo
in BASIC Stamp
Im trying to write a bit of code where I can control a servo with a potentiometer. I want to be able to move it to any angular position +/- 80degrees from the centre position. I should then display this position to the screen as it rotates.
Does anyone have any idea where I can start with this? I literally have no idea how to get the potentiometer to interact with the servo. Any bit of code would help to get me started!
' {$STAMP BS2}
' {$PBASIC 2.5}
time VAR Word
PAUSE 1000
DO
HIGH 7
PAUSE 10
RCTIME 7,1, time
time= time */ 185 'scale by 0.724 x 256
time= time + 500 'offset by 500
PULSOUT 14, time 'send pulse to servo
DEBUG HOME, DEC5 time 'display time value
LOOP
Well this is the code I have that lets the servo turn to its full capacity both ways. I need to limit it to -/+ 80 degrees and display that value to the screen. That is the part I am stuck on
' {$STAMP BS2}
' {$PBASIC 2.5}
time VAR Word
PAUSE 1000
DO
HIGH 7
PAUSE 10
RCTIME 7,1, time
LOOP
OR: read carefully where they talk about calculating the multiplier (185) and adjust it.
