combining strings with SPIN — Parallax Forums
TCTC Posts: 1,019
edited 2016-09-18 14:04 in Propeller 1
Hello all,
I have been trying for a couple hours to combine different strings and values, and make one string.
I used code from FullDuplexSerial to try and help, but it did not.
lets say I have in the DAT section,
sen_num  byte    "SENSOR_", 0
file_format  byte    ".CSV", 0
And I have a decimal value of 5 (not ASCII "5")
What I want in one variable is
"SENSOR_5.CSV"
Here is the code I have made, that doe not work. Is there something I am doing wrong?
PUB
  New_File(@sen_num, 5, @file_format)
PUB New_File(string_pointer, number, format) | string_temp, c, i
  repeat strsize(string_pointer)
    c := byte[string_pointer++]
    if c <> 0
        byte[string_temp++] := c
  i := 1_000_000_000                                    'Initialize divisor
  repeat 10                                             'Loop for 10 digits
    if number => i
      byte[string_temp++] := (number / i + "0")      'If non-zero digit, output digit; adjust for max negative
      number //= i                                      'and digit from value
      result~~                                          'flag non-zero found
    elseif result or i == 1
      byte[string_temp++] := "0"                                           'If zero digit (or only digit) output it
    i /= 10                                             'Update divisor
  repeat strsize(format)
    c := byte[format++]
    if c <> 0
  com.str(@string_temp)
  com.tx(13)
Thanks for any help
TC
  • The second last line should be com.str(string_pointer).
  • You also need to add a terminating null before doing com.str(string_pointer). You should add "byte[string_temp] := 0". So the last three lines will look like
      com.tx(13)
  • TCTC Posts: 1,019
    edited 2016-09-18 15:32
    Dave Hein wrote: »
      com.tx(13)
    Thanks Dave, But I am not displaying this on the serial terminal. This is to make a new file on a SD-card(file name). That is why I need it to be a variable. I only have the last 2 lines to check my code. But I will try adding a 0 to it. That might be where I am screwing up.
  • TCTC Posts: 1,019
    OK, this is a strange one from me. I do the changes
      com.str(string("File Name --   "))
      com.str(string_temp)
      com.tx(13)
    and the prop will reboot when it hits
    If I comment only that line, the prop will not reboot. There is nowhere in my code that tells the prop to reboot.
  • TC wrote: »
    Can you post the entire code? My guess is "string_temp" has been set to zero so you're writing zero to the first byte of RAM which messes up the Prop's clock settings. I've cause resets this way many times myself.
  • TCTC Posts: 1,019
    Duane Degn wrote: »
    I can, but it is really not that great. I still have a lot to do, I try to organised it when I can. Sorry about all the hacks. I'm working on 2 bugs now, one is this problem. The other one I am going to try to figure out if I can fix it first, before I ask for help.
  • TCTC Posts: 1,019
    OK, I cant even get this simple code working
      repeat strsize(string_pointer) +1 'the "+1" is only there to see the null-terminator
            byte[out_string++] := c
            com.tx(13)
            com.dec(c)   'I get correct value on "c"
            com.tx(13)
      com.tx(13)
      com.tx(13)
      com.str(string("out string --   "))
      com.str(out_string)
      com.tx(13)
      com.tx(13)
    I have tried different ways of doing " com.str(out_string) ". I have added the PRE-increment and POST-increment, i have tried the address symbol. And it will only show a few spaces and a "+".
    I am at wits end..... Please tell me what am I missing.
  • You appear to treat "temp_string" as both a buffer and a pointer. I turned it into a buffer and added a local pointer.
    Change the method "New_File" from:
    pub New_File(string_pointer, number, format) | string_temp, c, i
        if c <> 0
      if number <> -1
          if number => i
        c := byte[format++]
        if c <> 0
    '  com.str(string("File Name --   "))
    '  com.str(string_temp)
    '  com.tx(13)
      Check_Master_File '***** TEMP for checking *****
      return true
    To:
    pub New_File(string_pointer, number, format) | string_temp[3], local_pointer, c, i
      local_pointer := @string_temp
        if c ' same as if c <> 0
            byte[local_pointer++] := c
      if number < 0 ' don't add number characters if number is -1
          if number => i
            byte[local_pointer++] := (number / i + "0")      'If non-zero digit, output digit; adjust for max negative
            byte[local_pointer++] := "0"                                           'If zero digit (or only digit) output it
        c := byte[format++]
        if c
      byte[local_pointer] := 0
    '  com.str(@string_temp)
    '  com.tx(13)
      return true
    You should be able to uncomment the section below without crashing your program:
    '  com.tx(13)
    Rather than just checking or -1, the method will ignore any negative number since negative numbers will not work correctly in your algorithm.
  • TCTC Posts: 1,019
    Duane Degn wrote: »
          if number => i
        c := byte[format++]
        if c
    '  com.tx(13)
      return true
    Duane.... YOU ARE AMAZING!! I've been trying for a couple hours to figure out what I was doing wrong. Thank you so much.
    I had to change it to
    ifnot number == -1
       "RUN CODE"
    Your way worked, but it would still place a "0" in line. I wanted it so that if I place a "-1", it would skip loading a number. Trying to combine code where I can, and make things a little more efficient.
    Again. Thank you so much.
    TC
  • TCTC Posts: 1,019
    You taught me a couple things,
    1) look out using a variable as a buffer AND a pointer. Could be a problem later
    2) I did not know why others did
    but now I know.
    Thank you
  • TC wrote: »
    ifnot number == -1
       "RUN CODE"
    Sorry, I had the inequality sign backwards and I forgot the "or equal" part.
    It should have been:
    if number => 0
    I think using your "ifnot" with my original "< 0" would also work.
    ifnot number < 0
    This way it would skip any negative number not just negative one. A negative number would not be processed correctly by the algorithm.
    TC wrote: »
    Thank you so much.
    You're very welcome.
  • JonnyMacJonnyMac Posts: 9,834
    edited 2016-09-18 22:22
    I do this kind of thing all the time -- and there's no need to concatenate strings given the result you're after. Setup your dat section like this
    dat
      FileName      byte    "sensor_0.csv", 0
    Now it's a simple matter of changing that character.
      FileName[7] := sensornum + "0"
    Okay, so you say you want to change the extension of the file name? That's easy too -- here's a little method that lets you set the sensor number and file type
    pub set_filename(sn, ftype)
      FileName[7] := sn + "0"
      if (ftype == 0)
        bytemove(@Filename[8], string(".csv"), 5)
      elseif (ftype == 1)
        bytemove(@Filename[8], string(".wav"), 5)
      else
        bytemove(@Filename[8], string(".err"), 5)
    We use 5 with bytemove so that we copy the string (period plus three characters) AND the terminating zero -- this is necessary for string methods.
    Here's an actual bit of code I wrote for my friend, Bob, who uses the AP-16+ (which I co-designed and coded) in fun little toys. His latest project will randomize one of a hundred files within one of eight groups. Press the group button, get a random file. Here's his dat section
    dat
      FileName      byte    "PCFA_000.WAV", 0                       ' 100..199 .. 800..899
    And here's the code that updates FileName before playing the file.
    pub make_filename(grp, fn)
    '' Updates embedded string with file number
    '' -- gn is the group #
    '' -- fn is the file number (00..99)
      FileName[5] := "0" + grp
      FileName[6] := "0" + fn  / 10
      FileName[7] := "0" + fn // 10
  • You can make it simpler if you can guarantee that the filename won't be zero or negative ... seems like that should be a fair assumption. I had a similar idea for creating filenames for a SD card, and here's what gist of I came up with:
    DAT
      filename              byte      "LOG-xxxx.txt"
    PUB Record(counter) | t, i, m, div, value
      div := 1000
      value := word[counter]
      i := 4
      repeat 4
        if value => div
          filename[i++] := (value / div + "0")
          value //= div
        else
          filename[i++] := "0"
        div /= 10
      \sd.popen(@filename,"w")
    It doesn't combine strings, rather it overwrites part of the existing string. I fixed the length to four digits as I doubt I'll exceed 10000 recordings.
    If the period and terminator already exist in the target string, it's enough just to bytemove the three-character extension ... right?
  • TCTC Posts: 1,019
    JonnyMac wrote: »
    dat
      if (ftype == 0)
      elseif (ftype == 1)
      else
    dat
    That is great Jon, I will give it a shot. It is definitely a lot smaller in size, and easier to read.
    edited 2016-09-18 23:32
    You're absolutely right, Phil. I tend to be a overly verbose.
    TC: Given the dat section I suggested, this line would work:
      bytemove(@Filename[9], string("csv"), 3)
    Kye wrote a very nice and well documented string/hex/etc handler.
    ASCII0_STREngine.spin
    It is probably in the OBEX.
