ELEV-8-v3 Full-System-Check
hello
today i make my first Full-System-Check indoors with my new Quad with propellers,
according the instructions step 28.
for security: the landingGear was with 4 heavy book blocked.
HipHipUrray
its running, no problems nothing crashes
but one thing:
in the instructions reading "and the propellers will spin at low throttle"
- what understand you under "low throttle" ?
in my opinion: Verry fast throttle (spinning).
where can i change this in the GroundStation software?
and as attachment: firstQuadTest-1509-324.jpg
the quad-frame is a modified tarot-650-sport frame
diameter 560mm, high total 180mm
Thanks for tips and hints
best regards
nomad
HipHipUrray
but one thing:
best regards
nomad
The Elev8-FC, by default, spins the propellers when the unit is armed. Not enough to generate much lift, but enough to prevent the propellers from stalling if you ever put the throttle stick at the lowest position during flight, and also enough to remind you that it's running and will respond to the throttle if you bump it.
In the GroundStation software, you aren't changing the "RPM", just the length of the pulse sent to the ESC at the lowest throttle setting. Standard servo / ESC pulses range from 1000 to 2000 microseconds. You can make the low (armed) value match the low (disarmed) value, which will mean that the propellers do not spin when the unit is armed, but I don't recommend this.
In Ground Station 1.0.3, You can not enter a value less than 800. Is there another place you can do this?
To an ESC, which takes standard servo pulses, a pulse length of 1000 microseconds is the lowest "legal" throttle value, whereas a pulse length of 2000 microseconds is full throttle. You run the throttle calibration to get GroundStation to tell the ESCs what your lowest and highest throttle values are, so they aren't doing anything weird like auto-detection of the throttle range. There's no reason you should need to output a value of lower than 1000, but I allowed from 800 to 2200 because some servos allow that range.
So why do you need to specify a throttle pulse length of less than 800 micros?
@Publison + @JasonDorie
thanks for your answers.
i think, i dont change the values, its too dangerous, if i flight and the
throttle is on the minimum, i want no crash.
best regards
nomad
@geo_leeman
excuse my late answer:
i stand about 1 meter from the quad.
and the quad was locked with bigBooks....
regards nomadd
