jm rfid demo — Parallax Forums
jm rfid demo
Hi, im not clear on how to set up the display with this object and what to do with pins 28 through 31. Does full duplex serial need to be used through an lcd display, or is it something on the computer like the p.s.t.? Also is there something i need to set up for i2c or is that taken care of through com lines built in. Im using the professional dev. board. For the enable on the rfid reader and serial out i have 3.9k resistor to deal with the 5v and 3.3 volt difference. Thanks for the help!
''   File....... jm_rfid_demo__2015.spin
''   Purpose.... Identifies RFID tags while displaying a running timer
''   Author..... Jon "JonnyMac" McPhalen
''               Copyright (c) 2015 Jon McPhalen
''               -- see below for terms of use
''   E-mail..... jon@jonmcphalen.com
''   Started....
''   Updated.... 13 APR 2015
con { timing }
  _clkmode = xtal1 + pll16x
  _xinfreq = 5_000_000                                           ' use 5MHz crystal
  CLK_FREQ = (_clkmode >> 6) * _xinfreq                          ' system freq as a constant
  MS_001   = CLK_FREQ / 1_000                                    ' ticks in 1ms
  US_001   = CLK_FREQ / 1_000_000                                ' ticks in 1us
  DISPLAY_MS = 4_000
con { io pins }
  RX1     = 31                                                   ' programming / terminal
  TX1     = 30
  SDA     = 29                                                   ' eeprom / i2c
  SCL     = 28
  RFID_RX = 17                                                   ' RFID on PAB
  RFID_EN = 16
obj
  io   : "jm_io"                                                 '   basic io control
  time : "jm_time"                                               '   timing and delays
  rfid : "jm_rfid"                                               ' * RFID input
  term : "jm_fullduplexserial"                                   ' * serial io for terminal
  str  : "jm_strings"                                            '   string methods
var
  long  showtag                                                  ' true when data data displayed
dat
  lastsecs    long      -1                                       ' for clock updates
  timestr     byte      "00:00:00", 0
pub main
  setup                                                          ' start program objects
  term.tx(term#CLS)
  repeat
    show_clock(0, 0)                                             ' show running clock
    check_tag
pub show_clock(x, y) | s, m, h
  s := time.seconds                                              ' get seconds from timer
  if (s == lastsecs)
    return
  lastsecs := s                                                  ' save for next check
  h := (s  / 3600) // 24                                         ' extract hours (keep 0..23)
  m := (s // 3600)  / 60                                         ' extract minutes
  s //= 60                                                       ' extract seconds
  timestr[0] := h  / 10 + "0"                                    ' format time
  timestr[1] := h // 10 + "0"
  timestr[3] := m  / 10 + "0"
  timestr[4] := m // 10 + "0"
  timestr[6] := s  / 10 + "0"
  timestr[7] := s // 10 + "0"
  cursor_xy(x, y)                                                ' move cursor
  term.str(@timestr)                                             ' print time
pub cursor_xy(x, y)
  term.tx(term#GOTOXY)
  term.tx(x)
  term.tx(y)
pub check_tag | state, tidx, t1
  state := rfid.check                                            ' check on rfid tage
  ifnot (showtag)                                                ' if no tag showing
    if (state == rfid#READY)                                     ' has tag been presented?
      tidx := rfid.tag_index(@Tags, LAST_TAG)                    ' validate the tag
      if (tidx => 0)                                             ' if valid
        display_tag(tidx)                                        ' show the tag info
        showtag := true                                          ' enable timing of display
        time.start                                               ' restart timer (optional)
        t1 := time.millis                                        ' mark display sync point
        lastsecs := -1
      else
        rfid.enable                                              ' re-enable after unknown tag
  else
    if ((time.millis - t1) => DISPLAY_MS)                        ' time to clear last tag?
      clear_tag                                                  ' clear previous tag info
      showtag := false                                           ' mark cleared
      rfid.enable                                                ' re-enable rfid
pub display_tag(tidx)
'' Displays tag information if tidx in valid range
  if ((tidx < 0) or (tidx > LAST_TAG))
    return
  cursor_xy(0, 2)
  term.str(string("Tag.... "))
  term.str(rfid.address)
  term.tx(term#CR)
  term.str(string("ID..... "))
  term.dec(tidx)
  term.tx(term#CR)
  term.str(string("Name... "))
  term.str(str.pntr(tidx, @Names))
  term.tx(term#CR)
pub clear_tag
'' Clears onscreen tag information
  cursor_xy(0, 2)
  term.tx(term#CLRDN)                                            ' clear screen from here
  showtag := false
pub setup
'' Setup IO and objects for application
  time.start                                                     ' start/sync time
  rfid.start(RFID_EN, RFID_RX)                                   ' start RFID
  term.start(RX1, TX1, %0000, 115_200)                           ' terminal via programming port
dat { tags data }
  Tags
  Tag0        byte      "0415148F26", 0
  Tag1        byte      "0415148E0C", 0
  Tag2        byte      "041514AEA3", 0
  Tag3        byte      "041514A076", 0
  Tag4        byte      "04129C1B43", 0
  LAST_TAG    byte      4
  Names
  Name0       byte      "Luke Skywalker", 0
  Name1       byte      "Princess Leia", 0
  Name2       byte      "Darth Vader", 0
  Name3       byte      "Obi Wan Kenobi", 0
  Name4       byte      "Yoda", 0
dat { license }
  Terms of Use: MIT License
  Permission is hereby granted, free of charge, to any person obtaining a copy of this
  software and associated documentation files (the "Software"), to deal in the Software
  without restriction, including without limitation the rights to use, copy, modify,
  merge, publish, distribute, sublicense, and/or sell copies of the Software, and to
  permit persons to whom the Software is furnished to do so, subject to the following
  conditions:
  The above copyright notice and this permission notice shall be included in all copies
  or substantial portions of the Software.
  THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,
  INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A
  PARTICULAR PURPOSE AND NON-INFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
  HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF
  CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE
  OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
    mikea wrote: »
    Nothing needs to be done to pins 28-31. They are connected to hardware on the board. Full duplex serial would display the rfid data on the computer using PST.
    There is no setup needed beyond what is already done in the program. The enable is an output from the propeller and an input on the rfid so it does not need a resistor, but the serial output from the rfid is an input to the propeller and does require the resistor.
  • Thanks kwinn, the issue im having now is on the serial terminal it is only displaying a time counter, and the red/green led on the rfid reader randomly changes color. I folded the jumpers down away from the reader which seems to help with the leds switching, but maybe its coincidence they still do it somewhat.
  • I found a different demo from j.m. and it works well.,"jm_rfid_demo". however none of my rfid cards has an i.d. number on them, except the blue fob. It has a 10 digit number, but when i replace a 10 digit id from the dat section of the code with it its not recognized. Does anyone have code for just reading and displaying the id numbers?
    edited 2016-09-10 21:52
    mikea wrote: »
    Post (or link) the code which is working well. I'll see if I can modify to display the ID numbers of unrecognized tags.
    Edit: Is this the code you're using? I'll see if I can modify it to display unrecognized ID numbers.
    'Thanks Duane
    ''   File....... jm_rfid_demo.spin
    ''   Purpose.... Parallax Serial RFID Reader demo for the Propeller Activity Board.                       '
    ''               Use pins 16 and 17 as they have 3.9K resistors inline to prevent too much current
    ''               into the pins from the 5V RFID device. Make sure that the header power jumpers are
    ''               set to 5V (default), and to move the power switch to position 2 to power the headers.
    ''               Copyright (c) 2014 Jon McPhalen
    ''   Started.... 23 SEP 2014
    ''   Updated.... 03 OCT 2014
    con { timing }
      CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq               ' system freq as a constant
    con { io pins }
      TX1     = 30
      SCL     = 28
      RFID_EN = 16
    con
      #0, LSBFIRST, MSBFIRST
    con { pst formatting }
       #1, HOME, GOTOXY, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR
      #14, GOTOX, GOTOY, CLS
    obj
      term : "fullduplexserial"
      rfid : "fullduplexserial"
    var
    pub main | idx
      repeat
        repeat 2
          term.tx(CR)
        term.str(string("Present tag:", CR))
        accept_tag(@tagbuf)                                         ' wait for tag
        term.str(string("-- "))                                     ' display tag string
        repeat idx from 0 to 9
          term.tx(byte[@tagbuf][idx])
        term.tx(CR)
        idx := get_tag_id(@tagbuf)                                  ' lookup tag
        if (idx => 0)                                               ' display name for tag
          term.str(@@Names[idx])
        else
          term.str(string("-- Unknown tag"))
        pause(3000)
    pub setup
      rfid.start(RFID_RX, RFID_RX, %1100, 2400)             ' open-drain serial for RFID
    con
      {  R F I D  }
    con
      LAST_TAG = 3                                                  ' tag #s are 0..LAST_TAG
    var
      byte  tagbuf[10]                                              ' tag buffer
    pub accept_tag(p_buf) | c, idx
    '' Enables RFID reader for ms milliseconds
    '' -- reads tag bytes (if available) into p_buf
      bytefill(p_buf, 0, 10)                                        ' clear old data
      rfid.rxflush                                                  ' clear rx buffer
      low(RFID_EN)                                                  ' enable reader
      repeat
        c := rfid.rx
      until (c == $0A)                                              ' wait for $0A (LF)
      repeat 10                                                     ' rx 10 tag bytes
        byte[p_buf++] := rfid.rx
      input(RFID_EN)                                                ' disable reader
    pub get_tag_id(p_buf) | tidx, p_check, bidx
    '' Compares tag data in ram (at p_buf) with known tags
    '' -- returns tag index (0..LAST_TAG) if found
    '' -- returns -1 if tag not found
      repeat tidx from 0 to LAST_TAG                                ' loop through known tags
        p_check := @@Tags[tidx]                                     ' get hub address of tag being tested
        repeat bidx from 0 to 9                                     ' loop through bytes in tag
          if (byte[p_buf][bidx] <> byte[p_check][bidx])             ' if byte mismatch
            quit                                                    ' abort this tag
        if (bidx == 10)                                             ' if all bytes matched
          return tidx                                               ' return this tag id
      return -1                                                     ' return not found
    dat { tags data }
      Tags        word      @Tag0, @Tag1, @Tag2, @Tag3
      Names       word      @Name0, @Name1, @Name2, @Name3
    con
      {  B A S I C S  }
    pub pause(ms) | t
    '' Delay program in milliseconds
      if (ms < 1)                                                   ' delay must be > 0
        return
      else
        t := cnt - 1776                                             ' sync with system counter
        repeat ms                                                   ' run delay
          waitcnt(t += MS_001)
    pub high(pin)
    '' Makes pin output and high
      outa[pin] := 1
      dira[pin] := 1
    pub low(pin)
    '' Makes pin output and low
      outa[pin] := 0
      dira[pin] := 1
    pub toggle(pin)
    '' Toggles pin state
      !outa[pin]
      dira[pin] := 1
    pub input(pin)
    '' Makes pin input and returns current state
      dira[pin] := 0
      return ina[pin]
    dat { license }
      conditions:
  • It looks like I used a different version as my starting point.
    I used the code attached to the posted I linked to earlier. I've attached the modified version with the name "rfid_demo160910a".
    The code you embedded above looks like it displays the number of the card or the tag already?
    Do you not see this information?
    I modified the code you just posted to include an extra display of the serial number of the card just read but I doubt it will make much of a difference to you. This second program is named "rfid_demo2_160910a"
    I've read posts from JonnyMac where he stated his wish for modified code not to include the prefix "jm". I made minor changes but I still removed the "jm" prefix as JonnyMac has asked.
    Let me know if the attached code works okay. It compiles but I haven't tested it with an RFID reader. I don't have a Parallax RFID reader.
    Are you sure all the tags and cards you have are intended to be used with the Parallax reader?
  • Thanks Duane! I bought the cards either with reader from parallax or at the same time from parallax. I've used some of them successfully with the bs2. sometimes with the code that worked well that I posted, there were some symbols that showed up on the p.s.t., but not the typical numbers/letters of id's I've seen in example code. I will try these out and repost. Thanks again
  • When i tried "rfid_demo2_160910a" the serial terminal displayed:--unknown tag#= , present tag.
    rfid_demo160910a i cant get to compile. Even though the sub folder objects are open it will show error message that the objects are not in the library or open folder. I've tried saving the objects also.
  • mikea wrote: »
    Having objects open wont allow the top object to find them. This is an error in the Propeller Tool's instructions. You need to have the child objects either in the same folder as the top object of the child objects have to be in the Propeller Tool's library folder.
    I've attached an archive of "rfid_demo160910a".
    I don't know what would cause the other problems you're describing.
  • Thanks for making the file. It's showing a time keeper in the p.s.t. and also when i scan a card it will display "unknown tag address="
    , but no tag i.d. . I found a couple programs and tried it with bs2 and having the same issue. one bs2 is specifically for showing the id, but it wont read at all. The other bs2 code says id is unidentified, but it will acknowledge its been read. i wonder if there's a problem with the cards/fob, and if its possible to buy some that show their id's?
  • I don't know enough about the Parallax RFID reader and cards to know what could be wrong.
    I've only used the inexpensive MRFC522 RFID readers like those found on ebay. These readers use 13.56MHz cards and tags which are also very inexpensive.
    I've posted Propeller code in this thread which will read the serial numbers from the 13.56MHz cards and tags.
    I think I was able to write data to the cards and read data from the card but I don't think I got all the password features working correctly with the Propeller.
    I don't know enough about RFID to know how these cheap cards and readers compare with the Parallax reader but I thought the cheap reader worked well.
    I have used the Parallax rfid reader (#28140 rev C) in a project, and it can read and display the card/fob data. If this is the card reader you are using I can provide Spin code to read cards or fobs and display the data using PST.
  • Hi, im not clear on how to set up the display with this object and what to do with pins 28 through 31.
    I tend to write product demos that run via PST so that there is nothing else to connect. This is not a full-blown app, it's a demo so that you can learn to integrate the Parallax RFID reader into your own projects.
    As others have pointed out, there is nothing to do with pins 28..31. I put them into the listing as a reminder that they do serve a purpose and should not be used in your app without careful consideration.
  • @kwinn...The rfid reader i'm using is parallax 28140 rev. c. I would like to try your code also, thank you.
    I will post the test code I used after I find it and make sure it is the working version. May take a day or two.
    Here is the archive with the test code and a screen shot of the output to PST.
  • @Kwinn, thank you for posting the rfid reader code. For pin connections from the rfid reader it looks like enable is pin 2, i'm not clear on where to land "sout" the other line from the reader to the propeller. Also not sure what to do with rx1 and tx1.
    For the 40 pin dip the pin out would be:
    Pin 1 - P0 - rx1, data in from the rfid (needs 3.9 - 10K current limiting resistor)
    Pin 2 - P1 - tx1, data out from propeller - not used
    Pin 3 - P2 - rfid enable - enables rfid reader when low
    I tend to use the four port serial object with port 0 for debugging with pst and the rest as comms for whatever else I need.
  • The rfid serial reader is working now with all the code i have been trying it with. I'm not sure what changed.I ordered new tags to eliminate the possibility of a bad one and it worked with the new ones and now as well with the old tags. Thank you all for the help.
