Connecting computer to BS2sx
in BASIC Stamp
Trying to connect my laptop to a BS2sx on a carrier board that has a program loaded into it that is running. When I try to download a modified version of the program to the BS2sx, I receive the following message: "BS2 detected but not responding. Check power."
The BS2sx is powered up because the indicator light is on, the BS2sx is detecting the sensor inputs, and the BS2sx is continuously downloading data about the sensor inputs to my laptop (from the original program previously downloaded to the BS2sx, not the new program I tried to download).
My laptop says I have a good serial port connection. I've reset the BS2sx (by cycling the power off/on) both before and after trying to download the revised program, and by using the reset button on the carrier board, but I still get the error message noted above.
I've attached my laptop to another BS2 computer (using the same cable) and it recognizes the BS2 and I can download a new program to that BS2.
Any suggestion as to what the problem is and how I can solve this, and download a new program to my BS2sx will be appreciated.
Are you connecting from a serial port or using an adapter (if so, what brand)?
What is your current OS version?
Is this a USB 3.0 port?
I mark threads I reply to so I can follow up on them. I had no idea the OP posted a message on my "wall" (not a PM). In any event, Parallax does not directly support MacBS2 and the version you're reporting isn't listed on our website.
That said, I wonder if you have the latency setting in the FTDI driver on the Mac? We explain how to change it for Windows here: https://www.parallax.com/files/content/docs/Support/Downloads/Drivers/USBDriverTroubleshooting-V1.0.pdf
3.19 is an experimental version produced by an non Parallax employee.
http://www.muratnkonar.com/otherstuff/macbs2-experimental/downloads.shtml
You may have to contact the authour:
to see if he can help.
