Hand-held smart router
Phil Pilgrim (PhiPi)
Here's an interesting twist on "CNC" routers:
https://shapertools.com/
It's actually more of a CAC (computer-assisted control) device. For those who don't have the money (or room) for a CNC router, this might be a viable alternative.
Thanks for sharing that link, Phil. Interesting concept. Could have used that 3 years ago, but the company bought a used CNC 5' x 12'. Took me and another guy a month to get the DOS controller to talk to new G-Code.
He uses one of these starting at about 3:20.
Edit: removed forum tags on YouTube video.
I mean I do, it close company, but it's not PC.
I was a bit taken back because it is not a turn of phrase I have seen in the wild for many decades. I did not know it even existed in the USA.
The problem with the "self-deprecating" angle is that it is seen as comparing yourself to someone that you think has inferior capabilities.
In the PC world, any such suggestion calls for a death sentence.
I loath the PC world.
Are you negatively comparing yourself to the PC world?
I remember seeing somewhere that it will retract the cutter if you get too far off; it seemed to happen very fast, so I don't think a little spasticity will be a problem.
Yup, mentioned by Duane above.
erco, you seem to be having problems viewing stuff latley. Which browser are you using?
I used the "Youtube" button in the editor to add the link. I'm guessing the device you're using doesn't like the old YouTube API.
Here's what I see on my computer.
As you can see there's a note about he API being deprecated.
+1. Using the forum buttons will cause a flash file to be downloaded on Android, which is pretty annoying.
Good to know. I'll stop using the forum YouTube tags.
