Controlling a Latching Relay via One I/O Pin. — Parallax Forums
I found this idea interesting, even if on another forum: http://www.picaxeforum.co.uk/showthread.php?29157-Can-the-14m2-directly-control-a-latching-relay-with-a-5V-20ma-coil
The idea is to control a single-coil latching relay (alternate coil polarity to toggle relay contacts) using just one microcontroller pin and a series electrolytic capacitor. Saves power and pins. Probably not for mission critical apps, but when you need that extra push over the cliff...
"These go to eleven."
  • One pin for a single-coil latching relay... wait, what?...
    That's pretty cool, Have you tried it yet?, it somehow needs to be combined into one of your single servo bots.
    -Tommy
  • jmgjmg Posts: 15,199
    ...Also not for the average somewhat wimpy MCU pin, tho there are some MCUs now that can drive >> 30mA for LED use.
    Care is needed to check the Voh and Vol, & load lines, as simply finding 25mA or similar MAX rating, certainly does not mean that pin can feed 5V at 25mA into a Coil!!
  • Makes you really appreciate the Parallax Forums, with the addition of member example graphics, interest is increased along with clarity of the subject.
