Couple of terms and definition questions(noobs)
I just started to learn about robotics and this website, so I hope you help me to get started little bit easier.
Here are some questions below:
1. what is Basic Stamps?
2. what kind of programming language can I use for sumobot?
3. what can I do to understand better of how robots work?
Thank you so much.
Thank you so much.
https://www.parallax.com/catalog/microcontrollers/basic-stamp
https://www.parallax.com/catalog/books
In addition you also might like this book: https://www.amazon.com/Robot-Builders-Bonanza-Gordon-McComb/dp/0071750363
and have a look through the posts in this forum
Ooh, and welcome to the forums
Some to look at are the Basic Stamp Manual, What is a Microcontroller, Applied Robotics with the SUMO BOT, and the Sumobot Manual.
Tom
Welcome to the Parallax forums.
The BASIC Stamp is a series of microcontroller modules that are programmed in a language called PBASIC.
https://www.parallax.com/product/27218
The Sumo-Bot uses a BASIC Stamp 2 or BS2 and it's one of the more advanced kits in the Stamps-in-Class (SIC) series.
What's a Microcontroller is the start of the Stamp-in-Class series and it teaches how to use and program the BS2.
https://www.parallax.com/product/28123
Robotics with the BOE-Bot is the first robotics kit in the Stamps-in-Class series and uses a BS2 robot called the BOE-Bot.
https://www.parallax.com/product/28125
The BOE-Bot also has a large number of accessories and attachments that can be added to it.
Applied Robotics with the Sumo-Bot is the text that goes with the Sumo-Bot kit.
https://www.parallax.com/product/27403
Don't ignore the new S3 robot (uses the Parallax Propeller Chip - which is coming soon - another great place to start!
All the comments here are excellent - free pdf texts and check our learn.parallax.com
